Front Suspension/Axle Diagram
Been doing some searching and have not been able to come accross a good diagram of all parts associated with the front suspension and axle components. I mainly need the axle components but if someone has a good link or pic of the diagram with labels that would be awesome. Im rocking a 2000 Excursion V10 with 4x4. I have found some that are close but not the exact set up I have. Thanks for the help.
Have you looked here?
Genuine Parts for 2000 Ford Excursion|XLT 6.8L V10 - Gas
What parts are you seeking?
Try this:
http://www2.dana.com/pdf/X510-2.pdf
If you can't find your Bill of Material # use mine: 610999-1 it should be close enough for all but gears.
Tip: search the pdf for BoM#, then scroll up for the correct diagram.
jarrott
03-30-2005 03:46 PM
