DEF FLUID
#46
Dave, he quoted you because you said you hoped he'd never create a thread about having a huge repair bill costing thousands when in fact he did just that in creating his emergency thread... albeit about a different failure. I'm not trying to argue with you bud. Just explaining the link between your comment that Cappa quoted and another thread that he was referring to.
#47
OK Rodney, the light just came on ..... too much to eat yesterday so the brain is a bit (very!!) sluggish
My apologies to both you and Cappa
#48
Here's a little pointer if ya wanna save money.
DEF fluid is basically ammonia.
So .... If you use one gallon of ammonia to 1-1/2 gallons of distilled water mix it's the same thing.
Never had any problems with def contamination 👍
It will save you money. Dollar tree for the ammonia and a grocery store usually sells distilled water around 88 cents a gallon which would cost around $2.70 as opposed to $9-$16 at the truck stops or farm stores
#49
#50
Not a home brew,but they brew it for Ford.
STA-BIL® is starting off with a positive reputation.
Quote:
Originally Posted by wharrell View Post
Stabil:
Do you sell your product to Ford which sells it as PM22A Cetane Boost?
The reason I ask is that I saw your product recently in a Tractor Supply and it was in the same identical bottle as the Ford PM22A, just with the Gold Eagle Label.
I have a case of Ford PM22a in my garage, perhaps I can find a manufacturer's SKU code on it.
Thanks
Yes we (Gold Eagle Co) do package that product for Ford in addition to some other additives we package for other OEMs. We work closely with these OEMs to help solve problems caused by today's fuels whether it's gasoline or diesel.
Please let us know if there are any other questions.
Happy Friday!
Reply With Quote Multi-Quote This Message Quick reply to this message
Stabil:
Thanks
Happy Friday!
#51
QUESTION: I have a 2011 6.7. Yesterday, I filled my DEF Tank at a truck stop (pump not a job) and no matter how i put the DEF Pump nozel in the tank (yes the blue cap) it wouldn't pump. I had to "baby" the fluid into the tank. I did this for a few minutes and got pissed. Walked into the Truck Stop and asked what is going on. The sent a guy out with a special adaptor and it went in flawlessly. The guy wouldn't sell me the adaptor and i haven't found one one line. He said that with these "older" trucks we have this problem. The adaptor fit over the pump nozel and disspensed 6 gallons in very short order. This is the first time i have ever had this problem. Anyone else experience this?
#52
#53
#54
#55
#57
#58
Excellent post Tim! Just Googled it and it seems to be the perfect solution. As to it being certified, that's a bit ftarded but let's let that go.
http://www.fivestardef.com/def-magne...turnUrl=LwA%3D
#59
Hi Rodney, I remembered that well, because I thought I might need one too.
Decided to try the pumps I frequent before buying one cause a had a jug and ford hose the dealer gave me.
Only ran into one pump that needed it. That station closed and was remodeled with a newer pump. I pretty well know when I will be needing to fill and still have my original jug that I refill and have on hand.
#60
