2008 Ford Ranger Turn Signal "Relay" ?.
Hi, doe's anyone know where this "Relay" is located ?. I looked at my owners manual, and it doesn't even show one for the turn signals. Just a 15 AMP Fuse, i know there has too be more then that too make the signals work Correct ?.
Thank you so much, and please reply too me at (ddardanell@aol.com).
Thank's again.
Sincerely,
Don G. Dardanelli
San Jose, California.
Thank's again.
Sincerely,
Don G. Dardanelli
It will be in the repair manual, and no I don't have one either. I believe it is under the dash / steering column. You'll hear it clicking when it use. I had the same question, to confirm though. I'm too big to get under there easily and don't want to disassemble just to order the correct part and then do it again a month later. Good luck !
