A New Super Duty Engine is Coming...
#31
Perfect! That is just what I need for taking the kids to school! Make it an Energi so I never have to put gas in it.
#32
I've seen the medium duty durability issue mentioned a couple different times, and I think there might be something to it for Ford to keep the V10 in the class 4 and 5 trucks for 7+ years after they dropped it from the lighter trucks, but I've never seen any detail about it. Is it just speculation, or is there a known issue with the 6.2?
#33
#35
Ford - as a company - needs to continue to develop the V8.
America loves the V8! We really do! I may buy a 4 banger for my "commuter car", but I want a V8 for my fun or work vehicles. I really think Ford will benefit long term by continuing to develop the 6.2. I'd love to see 6.6 to 7 liters wth DOHC and direct injection. NOW we're talking!!!
#36
There's a big rumor going around right now that the 2017+ Raptors will come standard with a 3.5L Ecoboost and have an optional 5.0L Ecoboost(ish) engine that Ford has dubbed the Cobra Jet, a play on the old 428CJ's.
However, if Fords going to invest in an up tuned forced induction 5.0L for the Raptors, that will essentially stand in place of the 6.2L in the previous generation Raptors, then what's to say that a de tuned version of this (Cobra Jet) 5.0L won't find its way under the hood of the next gen SuperDuty?
It could make in the neighborhood of 500ish hp and 650lb/ft of torque or so, which would make it an awesome middle man engine to bridge the gap between the base 6.2L and the ultra expensive 6.7L Powerstroke.
Here's an article that discusses the new CJ 5.0L.
5.0L Twin Turbo V8 Ecoboost Raptor? - Ford Raptor Ecoboost Forum
Either way though, I'm excited to see what it could be, and what kind of numbers it'll put out. I remember years ago there was a rumor circulating that Ford was working on a more traditional 7.0L V8 for H.D Truck use. I'd be in favor of something like that as well...A return of the big block in Ford trucks!
Either way, I'm sure this new engine won't disappoint!
#37
Locally and probably nationally *** communications has been migrating from the diesels to the V-10 in it's F-550 bucket and utility trucks. As one tech told me, *** loves Ford but could no longer see the benefit in the added maintenance and repair of the diesel when the simple gas engine works just as well. It seems that the bucket lifts are now electric vs. hydraulic negating the need for the engine to idle all day while servicing it's above ground lines.
A simple big block replacement V-8 for the V-10 is the right answer for the heavier trucks.
Ram trucks locally are growing in numbers in the heavier segment, this means less sales for Ford / GM. Simple works and in this case, it's better.
#38
If the V10 is working well, and has been working well for the last nearly 20 years, is a replacement really needed for heavier trucks? Barring any significant gains in fuel economy, I would prefer reliability, and like you say, simplicity. The V10 is known, there are a bazillion parts readily available, as many are shared with all the taxi cabs and police cars of the last 20 years, and the service knowledge base is broad.
On the topic of Ram's growing numbers in the chassis cab market, my local fire department just picked up a new beautifully equipped Ram 5500 crew cab (with an all aluminum enclosed tactical support body).
It isn't hard to see why some fleet buyers are turning to Ram, and it isn't just the Cummins engine...
- Ram's chassis cabs are made with 50,000 psi steel, while Ford's current model chassis cabs are made with only 36,000 psi steel.
- Ram claims to "feature the largest front and rear brake rotors" in the 4500/450 and 5500/550 class.
- Ram claims to carry the highest GCWRs in this class.
- Ram provides a 100,000 mile POWERTRAIN warranty for its diesels, while Ford only provides a 60,000 mile POWERTRAIN warranty for its diesels, even though Ford does provide a 100,000 mile warranty for the Powerstroke engine itself.
- Ram offers the choice of a Manual 6 spd transmission, Ford does not.
#39
#40
#41
#42
Where are they getting this big block from?
GM stopped manufacturing the big block 6 years ago, on December 18, 2009. And those were the units sold to Workhorse, made on a limited number of shifts per week (not per day), the demand was so low. GM actually discontinued the big block in the Chevy trucks and cab chassis models two years prior, way back in 2007.
So if the EMS provider is getting their entire new chassis from Chevy, they are getting a small block... which might make a difference in terms of the expectations in "liter-ship" that Ford is competing against with any new or existing gas engine implementation.
#43
#45
There will be no TT 5.0 - it was designed from the start to be a high performance naturally aspirated gas engine. The EcoBoost engines are designed AS twin turbo engines. There could be an EcoBoost V8 at some point (very unlikely IMO) but it won't be in the same lineage as the current 5.0L Coyote.
