truck loses power to coil
Old 11-09-2015, 04:18 PM
brian.b's Avatar
brian.b
brian.b is offline
Hey guys my truck i thought ran out of gas but come to find out its losing power to the coil i can turn the key on with a meter on it power stays on for 1 second then goes away......what could cause this ......my truck is an 86 f 150 with a 300 6 cylinder......
Old 11-09-2015, 04:24 PM
WhatsAChevy?'s Avatar
WhatsAChevy?
WhatsAChevy? is offline
Check each of the wires for continuity.
Old 11-09-2015, 04:51 PM
brian.b's Avatar
brian.b
brian.b is offline
power loss
It will start when you crank it then it just dies out
Old 11-09-2015, 04:52 PM
brian.b's Avatar
brian.b
brian.b is offline
Where does the power wire get its power from for the coil?
Old 11-09-2015, 05:47 PM
jason832's Avatar
jason832
jason832 is offline
I'm having the same trouble with mine, suddenly one evening, it starts then when I let go of the key it dies. I've poked around with my test light quickly and can't find a problem.
I grabbed an old ignition module i had laying around, tried it, then the odd time it will start and run, but that's not good enough. So it may be the module that needs replacing.
Until I get another one shortly, this is what I did to get it running, since I need my truck daily.
1. Took the red wire (small one) off the solenoid, put it straight on the battery.
2. Ran a wire from the solenoid, into the cab.
Now when I want to start the truck, I put the key in RUN, grab the wire I ran into the cab, and touch it on a power source in the truck. (the back of my voltmeter that I have hanging down.) The battery does not get drained when the truck is off also.
Try this if you need to get it running temporarily.
Old 11-10-2015, 03:04 PM
1986F150six's Avatar
1986F150six
1986F150six is offline
brian.b,
Your 1986 4.9L originally came with the feedback [computer controlled] ignition. Is that still in place? If so, the computer can provide insight into what might be wrong.
Old 11-10-2015, 03:52 PM
WhatsAChevy?
Wiring does degrade over time and insulation fails. The engine compartment of our trucks is subject to the elements. ( Imagine yourself hanging on to a fender well under a hood going 70 mph down any of our great country's roads or highways). Road debris,salt,rocks and filth smacking you square in the face over and over again. After a while....you would look like Leatherface.
This goes for vacuum lines and hoses as well. Wiring as well as rubber does not last forever.
Dawn Butcher
07-09-2012 06:56 PM
clmurphy
09-15-2011 01:31 PM
restoringmy46
05-22-2009 03:19 PM
rob-o
01-07-2009 08:28 PM
eric88gt
11-01-2006 04:02 PM
Quick Reply: truck loses power to coil
