97 7.3 motor build PICSS!!!
Ok. I saw your post in the 6.0 forum. I lurk there reading all posts trying to learn, but I am a few weeks behind.
I have an early 95 7.3 and here is some pics to help you.
Others have answered, but I am going to confirm some of their answers. Please don't get upset.
AC compressor wire comes from same harness as clutch wire.
Coolant overflow and windshield washer fluid tank. I agree that the rubber hose is probably washer fluid to windshield.
Factory air cleaner. Looks like someone had the aftermarket 6637 filter installed on your truck. Notice I don't have the circuit breaker on the fender like you. It is probably something aftermarket.
Here is my power window and door lock switch. You have a power window and door lock harness in your door, but the switch has been cut out. The yellow and red 2 wire connector handing out of your door should be the motor wires for the power window.
Hope this helps. If you need any more pics, let me know.
Kevin
Kevin
