View Poll Results: Make you choice on ecoboost or 6.2 or diesel known
3.5 Ecoboost
13.85%
New 6.2L Gas engine
37
56.92%
Gen 2 3.5 Ecoboost
10.77%
Diesel for get gas
13
20.00%
Multiple Choice Poll. Voters: 65. You may not vote on this poll
EcoBoost or 6.2
#46
I'm not trying to start something but... I have done the same thing on various trucks and very few will shift out of 4wd under a load even if the light goes out and we all know how bad it is to run in 4wd on dry pavement....
#47
This entire exercise was hard on the truck though, and I've never heard of anyone breaking their 4WD components by using them on pavement. Not that it's a good idea, but none of us have had problems doing it. My F150's rear axle, on the other hand...
#48
A twin turbo 5.0 in an aluminum bodied SD would be fine. (Ford does need to lighten the truck up some more though). Put it at 400 hp/ 650 lb-ft of torque.
The 30% fuel economy advantage of diesels is long gone. Now it's more like 15-20% and that's not even accounting for the added cost of DEF as well as higher maintenance costs. Also even though fuel has went down, diesel is still higher than gas in most areas.
I have had two ecoboosts and three diesels- all could do the job. If what you need to tow could be satisfied by the specs that I mentioned above and you didn't tow 10k miles a year, you would be way ahead with an ecoboost.
#49
EcoBoost or 6.2
I dissagree about making them lighter. I was towing a 12000 lb mini excavator/trailer combo yesterday and the brakes didn't work on the trailer. My regular cab 08 weighs in around 6700# with me in it. The brakes were more then capable of stopping the load but on the first hard stop I had to make the trailer was pushing me making for a rather uncomfortable experience. I've been towing for a long time and have had brakes fail so this wasn't my first experience but it could have been bad. I also have 35x12.50 tires so that was 50" of tire fighting for traction. On a lighter truck with 245 or 265 tires I imagine that would have been a lot worse.
#50
That's true. The first one of these we did was in 2009, and my '08 had a manual T-case that I did the same thing with. If I remember right, I heard the tires scrubbing around that corner.
On the hill test, I personally wouldn't consider that exactly hard on the truck.... It's what they were designed to do and if that is hard on the truck it isn't something I want to own....
Did you have problems with the rear axle on your F150???? I missed that.
And just a suggestion for next years hill pull if it has a 3.5EB. What kind of EGT's are they seeing? I can't find anything yet on the 3.5EB but it's a problem for gas as well as diesels. I'm waiting inpatiently for the next event!... Still trying to justify an 11h+ drive to represent Iowa with a old 3v V10 farm truck but it sounds like a great time for the time spent.
#51
https://www.ford-trucks.com/forums/1...yone-else.html
#53
#54
#55
#56
#57
#58
And you would have been put out of service by dot or anybody. That shouldn't have moved, period.
#59
EcoBoost or 6.2
You are correct and I can't agree more but it happened and fortunately ended well. Back to the point though. A lighter truck regardless of tow rating would not have faired as well. And these crazy ratings of 30,000+ lbs of towing is down right dangerous. If the same truck was towing anywhere near that much weight and the trailer brakes gave out there is no possible way that load could have been stopped. Things like this need to be taken into account.
#60
You can't have a contingency for every foreseeable problem, otherwise we'd never leave our front porch.
