Lights out! No dome or cargo lights
I've got a 1998 F-150 extended cab that is having some trouble with the auxilliary lights. For some unknown reason, my interior dome light will not illuminate, and neither will the cargo bed lights. I can't get the dome light to come on no matter what I do. Opening the door won't do it, pushing the dimmer switch past the detent to turn it won doesn't work either. The bulb's filament appears completely intact. The fuse, which I believe is #8, is also not blown. The map lights on either side of the dome light work fine.
The cargo light also won't come on when the dimmer switch is pushed to the lights-on position. I haven't been able to inspect those bulbs yet, I plan on doing that tomorrow. I don't think it's the bulbs, since the done light looks okay. It's not the dimmer switch, because the dome light won't come on when the doors open either. Fuse is fine, unless I'm looking at the wrong fuse maybe? The only other thing I can think of is a break in the wiring which I really don't want to try and fix.
Help please! I'm getting tired of opening the door at night and not being able to see. Thanks.
SnubNose
SnubNose
Try fuse 14 in the interior fuse box, as well as the interior lamps relay which it the one all the way at the top of the fuse box, a small rectangular relay. The one under it is the battery saver relay which could also affect the courtesy lamp operation.
JJONES7432
11-10-2015 03:22 PM
thordehr
02-07-2015 11:19 PM
