"Lowered Expectations" - 1979 F150 Crown Vic IFS swap, Marauder 4.6 DOHC drivetrain swap
Old 06-12-2016, 07:40 PM
loudfords's Avatar
loudfords
loudfords is offline
Drilling jig and a good helper.
New holes swiss cheeses the frame a bit.
Old 06-12-2016, 07:45 PM
loudfords's Avatar
loudfords
Sorry for all the 2 picture posts, adding photos from a phone is a real PITA.
Holes all line up!
Got jack stuck under the truck when I went to lower it a bit and it got away from me. Needed the engine hoist to lift the frame up and rescue my jack.
Old 06-12-2016, 09:30 PM
jbehuniak's Avatar
jbehuniak
jbehuniak is offline
Looking great! I may have missed it, what are you doing for the brakes? Hydroboost?!
Old 06-13-2016, 07:03 AM
monkey-1's Avatar
monkey-1
monkey-1 is offline
Great progress. Can't wait to see more.
Old 06-13-2016, 11:19 AM
CelticOne's Avatar
CelticOne
CelticOne is offline
Regular User
Looks great, Chad. When you have it back up and running we will have to get together.
Old 06-13-2016, 08:02 PM
loudfords's Avatar
loudfords
Right now planning on CV booster and master cylinder.
Old 07-17-2016, 05:37 PM
fordtruckguy78's Avatar
fordtruckguy78
fordtruckguy78 is offline
how is your progress going , have you figured out the whole PB MC thing yet?
Old 07-18-2016, 08:22 PM
loudfords's Avatar
loudfords
Truck is on pause while I deal with some house reno stuff, I just laid 200 sq ft of hardwood that I need to stain and varnish, then I have to get my dad's truck ready for the trip to Arthur in August.
Old 08-07-2016, 03:35 PM
loudfords's Avatar
loudfords
Had some time to work on the truck yesterday, I put the engine in place just to make some space in the garage for staining trim for the house. I pulled out the crossmember between the cab mounts to see if the stock cats from the Marauder would fit within the frame rails but they do not. So I will need to have complete custom exhaust made. Maybe I'll look for some headers too... Still have to design and build the rear mounts for the lower control arms.
Got a bunch of work done on my dad's 51 yesterday too.
Old 08-07-2016, 04:06 PM
flowney's Avatar
flowney
flowney is online now
Pictures would be greatly appreciated.
Old 08-08-2016, 08:10 PM
loudfords's Avatar
loudfords
Nothing picture worthy yet unless you want to see the cats up against the frame
Old 09-15-2016, 09:37 PM
knucklecars's Avatar
knucklecars
knucklecars is offline
I DO!! lol....I am doing a 66 and was wondering what CV factory exhaust would be like
  #28
Old 09-17-2016, 05:53 PM
loudfords's Avatar
loudfords
Some pictures of cats not fitting.
  #29
Old 09-17-2016, 06:06 PM
loudfords's Avatar
loudfords
Saved up enough to buy some Pacesetter headers intended for Mustang Cobra/Mach 1. Got them fit up on the engine today. These things actually fit really well. Just had to grind a little bit off each engine mount plus the upper brace on the passenger side.
Ground some off the driver side mount to clear the pipe right behind the mount.
Passenger side mount hit at the top.
Pipe was rubbing edge of the aluminum brace at the top.
I will grind a bit of the frame for more clearance to make sure the pipe won't touch the frame when the engine torques on the mounts.
Hangs fairly low for the truck but will have enough ground clearance. Next step is to make a new tranny crossmember with exhaust clearance, rework the crossmember between the cab mounts since it currently goes through the bellhousing, and make mounts for the rear of the lower control arms.
  #30
Old 09-17-2016, 08:27 PM
Jigger2020's Avatar
Jigger2020
Jigger2020 is offline
Received 5,160 Likes on 1,689 Posts
well done Chad, I know it takes a lot of time to get them in there
Quick Reply: "Lowered Expectations" - 1979 F150 Crown Vic IFS swap, Marauder 4.6 DOHC drivetrain swap
