1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
06 5.4 SD Fuel filter clips?? Broke and cant remove
Old 01-17-2010, 02:59 PM
WishIhada7.3's Avatar
WishIhada7.3
WishIhada7.3 is offline
Trying to remove the Blue clips to change the FF I figured them to be like the old style. And that you just pry them up and out and pop the lines off....well both of them broke and the little pieces are stuck down in the fitting...Was i wrong to try and pull them up? I got some standard Ford Fuel line clips from the store but im not sure they are the same...Any help?
Old 01-17-2010, 03:43 PM
ReAX's Avatar
ReAX
ReAX is offline
I wouldn't have assume they went back to that style. My 02 5.4 uses the A/C style spring coupler clips on the filter. Maybe pictures would help jog memories here.
Old 01-17-2010, 04:23 PM
motown's Avatar
motown
motown is offline
People where breaking alot of these clips over in the F150 side, you can get them at NAPA, and I think the dealer. Of course NAPA will be cheaper. Below are the clip numbers For the Ford part #. My understanding is that the replacement Ford part is pink, so don't be alarmed when it comes in a different color. I broke one on my F150, this was befor they sold the repair part. Luckley their was a tap on the fuel bundle saying who made the part. I knew someone with that supplier and he was able to get me some clips. At first people where buying whole fuel bundles, because the clips where not available. You need to get a fuel line clip tool.
Standard 7L3Z-9S317-A (5/16" fuel line) kit includes: (This kit is possibly for Flex fuel only)
(2) Clips 7L34-9A317-AA
(1) Instruction sheet SK 7L34-9S317-AA
Flex Fuel 7L3Z-9S317-B (3/8 fuel line) kit includes:
(2) Clips 7L34-9A317-BA
Napa Kit 730-4913
Old 01-17-2010, 04:48 PM
fredsheffield's Avatar
fredsheffield
fredsheffield is offline
Nice Post Motown, I did not know they were available. Like you mentioned, when I broke one, we had to buy the entire fuel line. There should not be a special tool needed for his clips, on those you push down and they spread open.
Old 01-17-2010, 04:51 PM
WishIhada7.3
wouldnt it be 5/16??
The napa kit shows new fittings?? can the little clips not be replaced seperate?
Old 01-17-2010, 05:09 PM
FoxNotch's Avatar
FoxNotch
FoxNotch is offline
Originally Posted by motown
people where breaking alot of these clips over in the F150 side, you can get them at NAPA, and I think the dealer. Of course NAPA will be cheaper. Below are the clip numbers For the Ford part #. My understanding is that the replacement Ford part is pink, so don't be alarmed when it comes in a different color. I broke one on my F150, this was befor they sold the repair part. Luckley their was a tap on the fuel bundle saying who made the part. I knew someone with that supplier and he was able to get me some clips. At first people where buying whole fuel bundles, because the clips where not available. You need to get a fuel line clip tool.
Napa Kit 730-4913
Good post, good to know.
As for the 5/16" line, the first gas filter I got for my truck was that size, but was too small for the 3/8" line my truck uses. It also had the old style clips in the box with it.
When I returned it, the guy at the counter said there was a changeover which changed sizes and clip style. Based on this it sounds to me like you have the old style filter.
Old 01-17-2010, 05:19 PM
motown's Avatar
motown
motown is offline
I think some filter come with the old style clips, as the filter has several applications. The blue clip that breaks is a replaceable part of the whole clip assy. When they make the pipe they use a special machine to insert the whole clip assy, it has a barbed section that goes into the pipe. You couldn't insert a whole clip assy, you would need the inserting machine to do it.
Old 01-17-2010, 05:36 PM
WishIhada7.3
The clips that were on the truck were just ones you squeeze...no tab to pull up in the center..
So if i can remove the broken piece of both the clips will this pink update clip work for me? Im pretty sure it is 5/16 and not 3/8 but i guess i will buy both kits to be safe.
Old 01-17-2010, 07:19 PM
motown's Avatar
motown
motown is offline
My 05 has the blue clip, and you need the tool to get to get it off the fuel filter. Below is a link to some good info. from what I have read the size difference is the Flex fuel uses the larger size.
http://www.f150online.com/forums/200...lue-clips.html
Old 01-17-2010, 08:59 PM
WishIhada7.3
ya this truck is not flex fuel so it is 5/16...there are no metal fittings on the filter..just 2 plastic ones with the blue clips...im going to order the 5/16 kit from ford...and hope i can extract the lower piece's of those clips. Or get it disconnected some how with out breaking them.
Old 01-17-2010, 09:28 PM
1975StroppeBaja's Avatar
1975StroppeBaja
1975StroppeBaja is offline
Napa Kit 730-4913
Good post!! Reps sent.
Always useful when someone posts up the part numbers!!!
Old 01-17-2010, 11:06 PM
FoxNotch's Avatar
FoxNotch
FoxNotch is offline
Ford makes a flex-fuel option for these trucks?
Old 01-18-2010, 09:03 AM
motown's Avatar
motown
motown is offline
No, for the F150 only.
Old 03-23-2010, 09:11 AM
BIGGPIGG4x4's Avatar
BIGGPIGG4x4
BIGGPIGG4x4 is offline
Are these the same clips at the end of the fuel line to the fuel tank? Because I broke those and ford wants me to buy the whole fuel line.
Old 03-23-2010, 09:29 AM
FoxNotch's Avatar
FoxNotch
FoxNotch is offline
I believe they're the same.
Quick Reply: 06 5.4 SD Fuel filter clips?? Broke and cant remove
