460 Exhaust manifold studs?!?
#31
Question for those with the Banks headers though;
Did you re install the factory spark plug heat shields? Banks says its not required, but you can put them on if you like. For those that didnt reuse them did you make any other precautions to protect plug wires (sleeves, new wires etc?)
My heat shields are a bit rotten (I could fix them though) so I'm tempted to just throw them in my parts box...
#32
Hey,
Just noticed you're on the island. I'm in Nanaimo and have a few big block Fords. I'm looking at getting some Banks headers as an alternative to replacing a leaking manifold on my truck. Where did you end up ordering them from?
-Mike
-Mike
#33
#34
I ordered them through Summitt Racing, At the time they had the best deal, and the "cheapest" shipping. Well worth every penny though!
#36
#37
This was the easiest set of headers I've ever installed.
The following users liked this post:
#38
#39
#40
Even though you can purchase through Summit or Jegs they ship direct from Banks. Mine came with the starter heat shield, sway bar drop bracket and all needed hardware except the cat flange did not match mine or anything I could buy to replace mine but they list the catalytic converter flange shape in the specs I believe. I cut it off with a Sawzall and just had an exhaust shop flare a 6" piece of 3" exhaust tubing and used 2 heavy duty exhaust clamps torqued with about 10 ugga buggas.
#41
I pulled the part numbers from Banks' site for the Powerpack bundle for a Crew Cab, Automatic with Air Injection. I'm going to replace the EGR tube to maintain that function, but the Air Injection system will be deleted and the small port capped with a blanking plate. Grabbed the sway bar relocate bracket at the same time.
I ordered through Summit, as they had the least hassle to get the parts north of the border. But while on the Banks site, they offered a 10% off coupon if I ordered within 24 hours. I screen-grabbed that and sent it to Summit customer service and they say they are going to knock off the same amount from my bill. It's supposed to be refunded in 3-5 days. The parts aren't supposed to ship until the end of February, but I'm not in a rush. I have other work to do (camper tie-downs, some interior work etc.)
Definitely not cheap, but if I'm going to go in and fix a cracked manifold, I might as well upgrade it at the same time. I'm not a fan of the muffler that is on the truck anyways.
#43
Yep. The first thing I went out and did after placing the order. They are going to get a good long term soak before I get a wrench on them
#44
Ok, so now I'm back to the "headers looking pretty good" debate...
Did some more digging around online, and it seems what I am doing will only be a temporary fix. Most that have done the same repair have had another exhaust leak shortly after, usually with more broken bolts.
General consensus it that headers are the cure... So now I'm looking at headers; and the Banks seem to be the way to go, not only for quality, but for the fact that they come with everything, and doesn't appear I'd need a muffler shop to be involved...
Now I just need to come up with a good case for spending nearly $2000 on the exhaust system... this could be fun....
Anyone done a header swap that can help my case? I've looked at cheaper header options but by the time I get the other parts I need and/or have a shop fab up the rest, I'll be into it for nearly the same...
Would absolutely recommend this kit. But, as you noted its a tad pricey. If you do it, I don't believe you will be disappointed.
This is my build, if it helps:
https://www.ford-trucks.com/forums/1656928-banks-headers-and-air-pump-delete-project.html
countryartistjk
01-14-2012 12:09 PM
lvin4jc
11-08-2011 05:56 AM
mrf250
07-29-2009 11:23 PM
85lebaront2
04-13-2006 11:51 AM
PHOTOG101
04-22-2005 03:59 PM
