What else can go wrong
New to Forum. Hi all. I just put my 2012 Ecoboost 60,000 miles in the shop.
Problems found are:
-New Driver side window switch, window wouldn't close sometimes (short found)
- new wiper switch woiuld stay on intermittant when turned off(short found)
- Front wheel bearings need to be replacedgrinding noise from front end
- new water pump (was leaking coolant)
- new turbo needed (was leaking coolant and oil)
They also found a misfire so I have them changing the plugs.
Anyone recommend anything else to have checked or any other maintenance done?
Lucky it's all but plugs being done under factory warrenty (expires tomorrow) believe it or not.
Problems found are:
Crystal
martin78
11-29-2009 04:06 PM
