1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
2014 F250 - Will not start, tons of error message on dash
Old 02-27-2016, 04:15 AM
Bandguy's Avatar
Bandguy
Bandguy is offline
Goes to show you can't believe everything that you read on the internet!
  #62
Old 03-25-2016, 01:51 PM
Harrysagoo's Avatar
Harrysagoo
Harrysagoo is offline
Originally Posted by jdafonte
Just wanted to provide an update, So far I have not had the issue again.
I will provide another update if something happens or next Friday. Thanks again everyone for all the help.
Hi there, I am having the exact same alarms on my 2012 fx4 and the truck won't start. Would you recommend to take it to the dealer ? Any help regarding the issue would be highly appreciated. Thanks.
  #63
Old 03-25-2016, 02:08 PM
Bandguy's Avatar
Bandguy
Bandguy is offline
Check the connector over the parking brake to start. Try setting and releasing the parking brake.
  #64
Old 03-25-2016, 02:20 PM
Harrysagoo's Avatar
Harrysagoo
Thank you. That worked wonders for me.
  #65
Old 03-25-2016, 02:22 PM
Bandguy's Avatar
Bandguy
Bandguy is offline
She started?
  #66
Old 03-25-2016, 02:35 PM
Harrysagoo's Avatar
Harrysagoo
She started?
Sure did. Is there a permanent fix for this ?
  #67
Old 03-25-2016, 02:40 PM
Bandguy's Avatar
Bandguy
Bandguy is offline
Awesome. Many have removed the connector from the parking brake bracket and secured it with wire ties so it is suspended away from the vibration of the parking brake.
If you are more mechanical you can open the connector to make sure the pins look good first.
Bandguy.
  #68
Old 03-25-2016, 02:44 PM
projectnitemare's Avatar
projectnitemare
projectnitemare is offline
As far as a factory fix, no there isn't. Best solution that seems to be working long term is pull the harness/connector off the parking brake bracket and zip tie it up. Has worked for me for going on almost 2 years and many others have the same success.
  #69
Old 03-25-2016, 02:58 PM
Bandguy's Avatar
Bandguy
Bandguy is offline
Projectnitemare is the guy who connected all the dots on the problem and fix so he is the expert on this issue.
  #70
Harrysagoo's Avatar
Harrysagoo
Bandguy.
Thanks again. I really appreciate your help.
  #71
Old 03-25-2016, 03:10 PM
Harrysagoo's Avatar
Harrysagoo
I am definitely going to try that. Thanks.
  #72
Old 05-21-2016, 05:56 PM
heavy duty guy's Avatar
heavy duty guy
heavy duty guy is offline
well guys our F350 has done it again!!!!! It's been to Ford twice now after doing it and now it's sitting up here in the mine dead in the water again.
  #73
Old 05-21-2016, 08:24 PM
Bandguy's Avatar
Bandguy
Bandguy is offline
Sorry to hear this. What did they do for you back in February?
  #74
Old 05-22-2016, 10:46 AM
heavy duty guy
Well....... The first time they put batteries in cuz they said they were toast. So not true because the whole time I was troubleshooting it I had the battery charger on it so as to NOT drain the batteries (plus I had already load tested them from the start to rule them out) but miraculously it started after they did that! Oh plus they charged us $2200 saying it wasn't warranty (only 59,000 kms on it by the way) So then it came back up to the mine and was fine for a few weeks, then BANG it did it again sooooo off to Ford it gets towed again. This time they say it's the DPF doing it???? So then after they cleaned it apparently it started right up??? It comes back again and is good for a few weeks again until the other day. We had a left front wheel bearing failure on the way up to the mine so couldn't make it up and had to have it towed up, when the tow truck brought it up we went to start it and NO GO! Same starting system fault and all the rest of the bells and whistles, started fine for the tow truck guy an hour earlier. Ok I think I've pretty much covered it guys.
  #75
Old 05-22-2016, 01:08 PM
Bandguy's Avatar
Bandguy
Bandguy is offline
Wow. That is a saga of well intended but useless attempts to resolve your issue.
If you haven't done so, maybe it would be a good idea to open and reconnect the connector. If the truck stRts running get that connector off the brake bracket.
Good luck!
Quick Reply: 2014 F250 - Will not start, tons of error message on dash
