Scotty's 1952 F3, The Beginning (With Pics)
#123
#125
Also working on getting a bed installed. Even though it's plywood, it looks too nice for the truck right now.
It's 7 ply 3/4". I couldn't find any thicker.
I almost made the mistake of just soaking it with Linseed oil as recommended by a home center "expert". I saw a bed wood test of many finishes on Mar-K website. Linseed oil was the worst.
I love the look of a nicely finished bed but, I am going to use this as a truck and the Arizona sun destroys just about any finish.
The Mar-K test showed an oil based paint holds up the best so that's what I'm going to do. I bought some Valspar Tractor and Implement paint for my frame so that's what I'll use for now.
I still have to cut the wood for the bed strips and drill the holes. I ordered plain stainless bed strips. The polished ones must be amazing.
I'll post up the finished bed once it's done.
#127
#128
Scott, not sure if you guys ever get any rain down there, but if you cut the plywood for the strips I think you will have lots of layers peeling off in between them.
I used red oak for my by but laid the strips right on top of the wood without notching. This way when I put plywood on top of the strips the wood will not get damaged.
If there is no moisture to speak of down there than sealing the edges of the plywood is probably not a great concern.
#129
Jules, thanks for the input. We don't get much rain but, when we do it floods. The Mar-K tests had wood out in Texas sun, rain, heat and snow. I know it wasn't plywood but it was oil based paint that has been holding up for years.
I think you're right about de-laminating if I didn't paint it. I'll take your advice and not notch for the strips. I'll put them on top as suggested to hold it together. Good idea.
I'm "hoping" as long as I paint all sides and ends I'll be ok for a couple years at least. Until I do paint and body. If not, I'm only out $36.
I'll be getting loads of landscape rock and crushed granite for artificial turf base next week. I wouldn't be doing so if I had the nice stuff installed.
I was going to use my old bed strips but, I was short one.
#130
I just did a stain and SPAR varnish over that, we don't get the sun here in seattle but plenty of rain. My truck just sits outside. I plan to get a piece of 5x8 3/4 plywood and cut it to shape to fit in the bed for hauling stuff.
<a href="http://s1035.photobucket.com/user/SandersBallistics/media/20151128_140707_1.jpg.html" target="_blank"><img src="http://i1035.photobucket.com/albums/a440/SandersBallistics/20151128_140707_1.jpg" border="0" alt=" photo 20151128_140707_1.jpg"/></a>
#131
#132
#133
#134
#135
Jules, the flange in my bed lines up with the end of the bed .........so the wood HAS to go on top. Just thought you may have bought or made a trim piece.
Abe, I just need to be able to use the truck as a beater right now as I do mechanical repairs. I don't want to spend a bunch on beautiful bed wood at this point.
ANY wood I looked at locally was pretty expensive. Almost as much as buying the good stuff from a bed wood place.
You guys can all say I told you so if it doesn't make it at least until next year. I'm not afraid to admit when I screw up. This is temporary to get me by while I fix the important stuff.
