Seat swap help!!
Seat swap help!!
I'm wanting to change my seat out of my 65 cuz the springs are all broke and trashed I was wondering if a 67-72 will fit and if there is much of a size difference because the only seat frame I can find near me are out of those trucks and would the 65 seat upholstery fit the 67-72 thank you
A key part of what 6t6merc said is that the armrests (probably only, if they do at all) interfere with '67 and later seats in a '65 when you are tilting the seatback forward to access what's behind it. How often do you do that? If they interfere, just open both of the doors a bit and tilt the seatback forward. You certainly wouldn't be doing that while you are moving, so it's a minor inconvenience at best. You don't have to remove the arm rests. As it happens, I have oversized seats in my '66 and have no issues. Good luck!
If recall, seats wider 67 thru the 90's. Believe the seat tracks are same from 65 thru 69, not sure from 69-72, after that need to swap the tracks with later model seats.
Acquired 67 bench seat and did not care for the backside to bench fit, felt it set too high? Went salvage shopping and found 87 Lariat 40-20-40 contoured low profile seat for the 65; since I had a spare 67 bench seat, rather than swap tracks, I swapped the backs (removed 67 back and installed the 87). Tossed the cover and padding from the 67 bench and used the 87 cover and padding as a template for the upholster shop. Had to remove an arm rest, and remove small amount of material from the bench seat retainer using a 4" grinder to prevent it from stricking the fuel tank. Pleased with results.
Jrob69f100
09-09-2014 12:05 PM
1968F250LWB
01-11-2003 05:32 PM
