Fuel system wiring diagram
| Repair Guides | Wiring Diagrams | Wiring Diagrams | AutoZone.com
These are the same diagrams as in my Haynes manual. For a 1987 7.5L, figures 4 and 27 are applicable to me. The engine wiring diagram essentially just shows the ignition circuit, the chassis wiring diagram shows all the lights. I don't see the fuel system anywhere. I have 2 tanks but all the wires have been cut and I'm running an aftermarket pump on the rail using the front tank only. I'd like to get both tanks working again but most of the wires have been cut and/or spliced. Can anybody give me a diagram for the fuel system? Thanks....
That's not going to work. The OP has a 1987 model year truck that uses two in-tank low pressure pumps and a single high pressure pump on the frame rail. Electrically it is very different from what you posted.
Courtesy of Subford:
OP: Please do not forget there is a Dual Function Reservoir between the tanks and the external high pressure pump.
courtesy of Steve83
courtesy of Steve83
Thanks rla! That is a huge help. I started to tackle this project when I got the truck but got sidetracked by other more pressing issues. I'm currently pulling the transmission to replacea chewed up ring gear on the flywheel. I have been hesitant to go from my current setup back to stock since the truck was originally a 5.8EFI engine, but after taking a second look at the parts, I think I can make everything work once I get some low pressure pumps in the tank.
On a side note, does anybody have a good source for the dual function reservoir? I found what I think might be the right part in the LMC catalog, but it was $250 - ouch! I'm never opposed to junk yard parts, but I like the peace of mind that new parts generally provide. Thanks again!
Thanks. I'm still trying to figure out why there is no wiring diagram for my truck specifically.....
I spent the weekend replacing the flywheel, clutch,steering components and fuel pump. Once I get everything buttoned back up, I'm hoping to back the truck out of the garage and use the bucket on my tractor to lift the bed off and tackle the tank issues.
Somewhat off topic, how difficult would it be to retrofit a mechanical fuel pump? Would it just be a matter of getting an older timing chain cover? I've been reading reviews on electric pumps and the theme seems to be either pay $50 and replace every 6 months, or pay $400 and get a longer service life. Are mechanical pumps more reliable? I know they have their issues if the truck hasn't been started in a while, but thought it was worth asking.
Edit: I'm on my third electric fuel pump this year.......
fiftyfordfloored
07-06-2019 11:00 AM
fredweberjr
07-27-2008 04:44 PM
van-man
02-18-2006 03:33 PM
