Rough country lift for diesels only?
That kits springs have a higher spring rate for the weight of the diesel truck. Look into the 4 inch zone off-road kit on their site it's just over 1k. If you like it call sbc off-road out of Georgia they can normally save you quite a bit of cash with free shipping to your door. Zone is a sister company to BDS so it quality stuff. I've used them several times and have been very happy with their products and support.
No it is the rating of the coil springs in the kit they are specific to either a gas or diesel truck. No matter the lift once you get to a 4 inch lift or greater the front drive shaft will rub the cat on a gas engine truck. You can loosen the bolts by the manifold and try to shift over the cat or have a piece welded in to move the cat slightly.
