Transmission ratio questions
We have all sort of crazy regulations here in the UK about what can and what can;t be changed on a vehicle for it to retain it's original identity. It's original identity is very important in the UK as vehicles built prior to 1960 are exempt from lots of tests, inspections and often expensive road tax. You just insure and go.
If you mess with the chassis, or change too many items from the mechanical side, you also lose the identity and the vehicle has to go for a very thorough and expensive test which it will not pass as the moment it loses it's original identity, it has to conform with modern standards which would be impossible to achieve.
Hence I must have a truck with its original chassis, motor and trans to import and register it as an original truck. I can then swap out various components within reason to make it more user friendly - the axles and transmission for example...
My issue is that I'll be running 30" tires, not the stock 36", taking it from just about tolerable, to just too damn low.
The prospect of a 5 or 6 speed modern and efficient trans does appeal though...
ekm71f100
02-17-2011 08:24 PM
Sandidande
04-16-2007 07:25 AM
