Alternator/External Voltage Regulator 72fordf100
Just because it's new doesn't necessarily mean it can't be the problem. Since you said " At times after removing the screwdriver the engine was still turning" I think the solenoid is defective. And I think that is where your short to ground is. If you have a multi meter set it to 200 OHMS in the resistance range. Touch the black wire to a known good ground. Then touch the red wire to all 4 terminals on the solenoid one at a time. If the multi meter never registers any resistance then the terminals are open and no internal short. If it registers some resistance on one or more terminals then there is an internal short.
The coil is receiving power @ .43 on the multi meter, I am not sure if that is good or bad. Like I have said before that this electronic ignition & module is throwing me a curve ball. The wiring is totally different from the original schematics. there are 2 wires coming from the module that are not even connected to anything. I've checked online for the wiring diagram for this electronic ignition module & can not find anything that goes to my 72 Ford F100 or any years close to it.
on
BP, is your electronic ignition Ford/Motorcraft? If it is, then go to Fordification.net for a 76 wiring diagram, and print it out. Print the 70 diagram that Orich provided you earlier. Get out your colored pencils, and start identifying the original wiring 1 wire at a time. Make a note where there are discrepancies. Now take the 76 diagram and start from the distributor and work back to the module, and there to the ignition switch, coloring 1 wire at a time, and noting any discrepancies which you can compare when done. Remember that you have a mutt and will have to combine two different systems. As a retired USAF electrician and technical training instructor, this was how I taught my troops how to troubleshoot electrical circuits. Remember to write down everything and document everything.
Electronic ignition
Thanks for the advice. Color coding the wires would help me & trying to figure out which wires are there now. But if wires have been changed from the previous owner I may have to cut through the wire harness to access the wires that are not correct. If I have any other options I would need some ideas on how to go about that. Right now I am not sure if the module is getting power. I am going to test all wires going to & from the module to see if power is flowing through it. The only thing is that I do not have the wiring diagram for this electronic ignition. my elctronic ignition is a Street Fire I believe I posted the model # on a previous post
72 Ford F100
Thanks to all my FTE family for your help. I have decided to change my alternator to a 3G one to get rid og the voltage reg. wiring clutter & fix the wiring problem I am Having with my Street Fire electronic ignition. I found the website for my electronic ignition (Street Fire Ignition products by MSD Ignition). I found out that there a couple of wiring problems with the positive wires leading to the ignition switch.
MSD Street Fire Ignition for 72 Ford F100 Ranger
Does anyone know where the small red wire goes to the ignition (which slot) for the MSD Street Fire electronic ignition kit? There is also a 12V wire that I am not sure of where that one goes to? I also have a Red wire with a green stripe that has a connector that comes from the engine firewall. The connector has two more wires coming from it, a white wire leading to the oil pressure switch & another red wire with a white line leading to the coolant temp. switch? The red & green wire is not connected to anything now. It was connected to the small red wire coming from the electronic ignition which did not belong there as I stated above. I will post pics in my album.
ryank59701
10-19-2015 02:04 PM
MeatRo
Electrical Systems/Wiring
04-25-2015 11:19 AM
Littlehoe
08-11-2010 09:40 PM
