79 F150 Cummins Swap!
Looks like you're getting close. I was going to use the Dodge IC & Rad but decided to sell it and get a SD IC and keep my aluminum rad. Also didn't feel like modding the inner fenders to clear the IC tubes.
Been running mine for about 4-5 months and am glad I did it.
Ryan
Ryan
From what I read it was actually a trans fluid "heater" to help with cold weather since the coolant will be heating the fluid up to whatever temp the motor is. I didnt like that so I pulled it off and will just be running a nice big cooler up front.
I think I'm going to hold out and make an insert and put in new gauges behind the clear plastic lens. Will probably use a GPS speedo.
Ah haha alright, I gotta figure out what I'm gonna do using the 47RE. Its electronic not mechanical (not sure if your 47RH is the same?)
Also when you bought your new carpet to use the dodge tcase shifter did you just buy a 2wd carpet and cut your own hole? And who did you get the carpet from?
The truck had somewhat new carpet. The hole for the stock tcase shifter just needed to be increased. I still have a hole where the trans shifter was, but I cover that up with my gloves Need to put in a patch.
Oh cool, well thanks! Hopefully mine will work out like that as well!
I got the cross member built tonight for the transmission. Now I gotta pull the motor and trans BACK out for the last time hopefully to clean and POR15 the frame, run all the new lines and wires, put the 38 gallon rear tank in (had to pull the front one to fit the trans), put the lift in, convert the front to 8 lug and swap the rear axle in.
Then the motor will go back in and the wiring will begin!
http://shop.advanceautoparts.com/p/a...earchTerm=2268
Got a couple things done recently. I've been so busy with work and life I haven't had much time to get out in the shop.
Got the new Gen 3 exhaust manifold on and it looks great! Slid the HX40 on there and it fits perfect. Didnt get a pic of the turbo bolted to it yet.
Also got the frame plated and the front cross member is getting there. I moved the new cross member forwards so I could make it straight. Made sure the fan and radiator didnt hit as well.
Also got the new tires in for the truck along with the rest of the parts! I have to POR15 the frame now, then all new stainless lines, get the fuel tank in, new axle, convert the front to 8 lug, get the lift in and then I can get the motor back in. Then start on wiring.
#28
Finally got some time to work on the truck this weekend!
Got the rear axle all cleaned up, disk brakes on it, painted and installed with the lift. Also got the frame stripped, cleaned up and painted. When I pulled the old tank out I found a pretty big rot hole lol and some pretty nasty looking water/gas came out.
I got a skid plate from a 1995 powerstroke from a buddy and used that with my new 38 gallon tank for the rear as well after I got that painted up.
Got the front axle completely out and disassembled. Working on cleaning that up and converting it 8 lug.
