1974 F100 Build Thread IFS, IRS, 5.0 EFI, AOD
Crown Vic IFS has been used and documented well. I got the Police edition so it should be a little more heavy duty. Haven't seen anyone use an Explorer IFS. That could be interesting.
I most certainly did mean IRS, I guess the R and F keys being so close together didn't help. Or maybe I subconsciously refused to type IRS because of what it usually means?
Anyway, that is the question. It seems to me that the Explorer rear end setup would work better and be more in keeping, strength-wise, with the truck-ness of the vehicle.
I have a friend who put a Jaguar IRS under a Toyota pickup and he said the improvement in ride quality over bumpy roads was amazing.
R.
R.
#28
R.
R.
#29
#30
Update
I've been really bad about updating the build and I have made some progress.
I've rebuilt the engine using stock heads, cam and intake from a fox body mustang.
And painted it the body color of the truck.
The motor is finally mated back with the transmission and is back on the frame.
With all the swaps going on we have ran brake lines, fuel lines, attached the steering, moved the gas tank back (even though I was told a stock tank would work with the irs swap), installed a mark VIII fan, and made a custom bracket for my AC compressor. I'm sure I'm forgetting a few things.
Right now we are mocking up the rest of the vintage air system, wiring and other things on the cab of the truck before we blast it and start the body work.
This is how she sits now.
