Compatibility for Dually rear axle swap??
on
What do you mean by compatible? Bolt-in? Only 67-72 F-350 Dana 70's have the correct spring pad width and axle length. You could go with other year F-350 dually axles, but will have change the spring pad widths, and or drive shaft length and u-joints. You can go up to 98 10.25 axles for wheel compatibility, but you cannot use 99+ Super Duty axles due to the 170mm lug spacing. Check the big truck/heavy equipment yards for better pickings as there would be a better selection of axles. Don't worry about gear ratio as it is more important to find a good axle first. The gears can be changed later.
flainn
19
07-23-2012 06:15 AM
wood4d
06-05-2006 11:09 PM
sc4x4
10-24-2005 07:53 PM
