Failed smog test at idle
Due to my own stupidity I need to have me truck pass smog to retain my classic vehicle status, I wrote down the wrong odometer mileage for my renewal.
I failed the idle CO test, I'm at 5.91% and needs to be no greater than 3.5%. High RPM test was fine just a problem at idle speed.
I interweb searched for information and have found two extreme opposites of what to do. Some say it's too lean and to open up the air/fuel screw. Some say it's too fat needs to be leaned out. Both of these can't be true? They are entirely opposite of one another! If the CO level is too high shouldn't I lean it out and even increase the idle speed? Right now my idle is at 500, I don't like high idles.
Any help for me is appreciated.
Check or replace all vacuum lines to the carburetor. If you have a timing light, set the advance at TDC. Lean the idle screws out as much as you can and raise the idle speed as high as you can get away with.
Talk your way into the shop with the tech. Play dumb. Have a screwdriver. Lean and raise the idle and spook the numbnuthz. You will pass.
Worked for me.
Semper Fi
Worked for me.
Semper Fi
sfc11b
25
02-18-2007 06:33 PM
Fordiod
08-29-2002 04:43 PM
madcow
08-01-2001 09:16 AM
