Oscar project questions and updates
#106
Got to my first big swap meet this weekend. It was at Charlotte Motor Speedway and it rained all day (in fact the whole 4 day event). But, that mage people willing to deal. So, I came away with the following:
- Awesome old tachometer I have big plans for
- Set of gauges, oil psi, water temp, amperage
- outside mirrors, sleeker car style I think I will like
- 2 am/fm push button radios, hoping one will work
- rear view mirror that is a single piece with the visor bracket
All that and a Philly cheesesteak for about $65. Sure wish I had a couple.hundred I could have spent cause there was lots of good stuff there. Sucks being on a tight budget.
I'll post pics as I clean things up and install them. I also came up with an awesome.idea for a cupholder and once I weld it up I'll show y'all that as well. Its a stroke of genius I think. Lol
#108
#109
None that I know of. Only thing I know is taking it to a Plater that can remove the old chrome, polish it back smooth, then re-plate it.
#110
That's kind of what I figured. Maybe we can come up with a better name than "pits" for the little marks and then it will be cool - like "patina" means rust but the word adds $100 to everything and instantly makes it cool!
One other question: I want to replace my radius arm bushings (the ones at the back by the cab) and it seems to me I remember that if you pull the nuts the whole front assembly will pull forward and you can replace those bushings. But I am not sure. Does that sound right?
#112
#113
I tried that radious arm trick once. MAJOR PIA!!!!! easier to drop the whole thing. Didn't you just do the I-beam bushings tho?
#114
#115
#118
Whew! Went through a wild few weeks, but I'm back in action now. My power steering started leaking all over the place, but some new fluid with stop leak seemed to swell up the seals enough to get me through until I can tear in and replace that upper seal. Hopefully this weekend.
I have had all kinds of electrical gremlins. It's crazy how things work one day but not the next. Here's my current issue -
Occasionally the turn signals stop working and if I jiggle the key in the ignition switch just right they start up again. Any ideas? That seems so weird to me. I didn't think the turn signals went through the ignition switch.
Hope everyone else is good. I'll get to reviewing the other threads shortly.
#119
Back in a day, I used to have a wod of keys on my key ring. Something of the same sorts happened to me, I changed the ign switch, and used a one key keyring for the ole girl. Still do the same today. Like presto magic, it still works.
It is possible to remove the keyed tumbler to use with the new ign switch.
