HELP 2001 4.5 Air Conditioner
Old 07-27-2015, 10:58 AM
WARedBear's Avatar
WARedBear
WARedBear is offline
Moving cross country. Wife is driving my F-150 and the AC cuts out about 15 minutes into the drive. It may or may not come back on. Getting check engine light code cylinder D. Clear that out and AC again works for 15 minutes. Told I have a vacuum leak. Have the dash apart looking. In Dallas so I need help fast.
Old 07-27-2015, 12:22 PM
brokenleg's Avatar
brokenleg
brokenleg is offline
cylinder D? whats the cylinder have to do with AC? Take it to a garage and get it fixed...otherwise Drive it.
Old 07-27-2015, 12:59 PM
WARedBear's Avatar
WARedBear
I habe been advised that a vacuum leak will cause this error. Driving it is not an option because it is to hot. Anybody with actual helpful advise?
Old 07-27-2015, 01:02 PM
brokenleg's Avatar
brokenleg
well we can tell you all kinds of stuff what could be wrong. but you are there with the truck. if you are in a hurry. a shop probably is your best bet.
Old 07-27-2015, 01:22 PM
auskip07's Avatar
auskip07
auskip07 is offline
what specific code is it throwing? 4.6l engine btw
Old 07-27-2015, 04:00 PM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
You were probably advised wrong. A misfire on cylinder 4 ("D") will not cause an A/C fault nor will a vacuum leak cause either of your symptoms.
Most likely, the intermittent AC is due to a worn clutch, see HVAC FAQs.
The misfire is probably a COP/plug.
1999-F150
1997 - 2003 F150
08-12-2017 07:46 AM
WARedBear
1997 - 2003 F150
07-27-2015 11:26 AM
elkslayer
20
08-10-2007 10:34 PM
crazie0025
10-19-2006 11:12 PM
bolingmike
1997-2006 Expedition & Navigator
07-07-2005 05:54 PM
Quick Reply: HELP 2001 4.5 Air Conditioner
