Belgian 1954 F100 build
#33
They did that last nite on Leepoo (sp?) and Pitbull. History Channel. Built a customized olds cutlass and wrapped it in vinyl rather than paint it.
This is my good friend Mike Janis's ProMod:
It's a complete vinyl wrap, no paint no decals/stickers, carbon fiber body. Racers are doing it to save weight, Mike says it is about 10# lighter than paint, can be rewrapped in same or different design in a few hours. All the Nascar Sprint cup cars are vinyl wraps now, can change schemes, sponsors, even team/driver #s in a couple hours.
#35
I am not in the business so don't quote me, but I've heard numbers like 1500.00 for a single color wrap to 2500. for full color custom graphics tossed about. Still a lot less expensive than even a basic 1K paint job, and it's finished and ready to go in an afternoon.
I think it a safe bet there are more than a couple installation videos on youtube, try searching.
#37
#39
#40
#41
#42
Might want to radius the top corners and taper the sides of the male die slightly to better match the profile shape as well, otherwise when you put in the patch the change in profile, not just the width, will be very difficult to blend, making the patch obvious. If you look closely you can see the whole top of the rib has a low crown with radiused upper corners, it's not square. This was likely a deliberate choice of shape to counter the metal's natural spring tendency to concave both across and lengthwise if stamped to a sharp square.
#43
Thanks for your input.
I haven't rounded them yet as I want to see how it forms with the correct bottom width first.
Since the male die is 1/4" narrower than the female one I don't think it has to be angled to get the correct shape.
Only had time to fabricate the female die today so I'll know more after the next test tomorrow.
#44
Got 1 of the running boards done.
Also king pins, brakes and shocks are all done.
Working on the engine, electricity and glass still to go.
Also found someone to paint the hood, won't be airbrushed but painted by an art painter with a love for cars, his work looks awesome.
All I need, to be able to finish it are 15x8 steel wheels.
Anyone know where one can get 15x8 Wheels with hubcaps and trim rings?
#45
Received 4,135 Likes
on
