Towing MPG comparison
Old 07-31-2015, 06:20 PM
Airstreaming's Avatar
Airstreaming
Airstreaming is offline
Originally Posted by IDMooseMan
I was under the impression that having the trailer nose-down caused excess pressure on the front axle of multi-axle units and increased the chance of trailer sway. Nose-up for trailer was supposedly the "safer" condition when level was not attainable.
Your point about front axle loading on the trailer is correct and with too much you will see the result in overloading the front axle as compared to the rear.
But nose slightly down is better than nose up. In a condition where trailer begins to push the truck (going downhill for example), nose up can result in an upward vertical component or lifting force on the rear of the truck. This condition can go bad quickly from a vehicle dynamics perspective. So level or nose slightly down is the way to fly.
Again your point about too much nose down should be avoided.
Old 08-01-2015, 10:24 AM
snowdog79's Avatar
snowdog79
snowdog79 is offline
Can I suggest that the trailer might just be a bit heavy for a short bed 250 rear suspension? A really long trailer with a relatively short wheelbase truck can be tricky. You can only dial out so much rear squat with a weight distributing system without causing unintended issues. How about the simple step of adding some air bags or overload springs? Then the WD hitch is just fine tuning the combo for correct attitude and control, not making up for the easy-to-squat F250 rear end. I bet the ride would be much improved, too.
Old 08-01-2015, 01:14 PM
KW7DSP's Avatar
KW7DSP
KW7DSP is offline
That seems low. My 7.3L got 21 highway empty (Highway Gears installed. Towing the 12,000 5th wheel I got 12 average with really good on flat freeway, but most of my driving was two lane and curves or hills. With the camper and towing I got 13 average and with the small 5th wheel and towing I got 14mpg. Something isn't right here.
Old 08-20-2015, 02:15 PM
tjbuggie's Avatar
tjbuggie
tjbuggie is offline
I just made a run from central TX to williams AZ 02 f250 7.3 with my Trailer that weighs around 10.5K and averaged 10 mpg.
Old 08-22-2015, 12:58 AM
mrollings53's Avatar
mrollings53
mrollings53 is offline
My '95 F250 weighs in at about 9200lbs, and I get about 5.5 MPG with my 460, so don't feel so bad. The transmission is dying which I bet adds to my extra fuel consumption.
How heavy is that camper, and do you have suspension upgrades? Also, you can tow a trailer behind a trailer in Oregon?
Old 08-22-2015, 07:13 AM
petrokiller's Avatar
petrokiller
petrokiller is offline
I have overload springs factory.
Are F350 springs stiffer from an extra leaf in the pack?
I could easily get the sag out with my round bar WD setup with just chains and friction sway control.
Old 08-22-2015, 09:13 PM
petrokiller
Educate me on my springs please. F250 stock rears.
Somebody post their F350
Old 08-23-2015, 03:45 PM
IDMooseMan's Avatar
IDMooseMan
IDMooseMan is offline
Brad, here is my factory setup:
F350 Rear Leaf Springs
Not sure if this is OBS vs. NBS thing either. We have the same number of leaf springs (6), just different setups.
Old 08-23-2015, 09:17 PM
petrokiller
Craig thanks. Yes mine is NBS. I think your setup has 2 overloads to my 1
Old 08-25-2015, 02:28 PM
Thor'sHammer's Avatar
Thor'sHammer
Thor'sHammer is offline
2005 F350 CCLB DRW 4xx4 6.0L/5R110/4.10, 122k miles. Stock except for egr delete.
2014 Crossroads Zinger ZT33BH 36'6" x 11'9", 11k (loaded).
Unloaded mixed driving, 16mpg. Loaded with 500lbs in bed and hitched to 11k camper, 12mpg.
Old 08-30-2015, 09:38 AM
Snowseeker's Avatar
Snowseeker
Snowseeker is online now
The worst I ever got with the train in my sig is 12.5 with 10-20mph headwinds. I have been averaging 13.5 most times with it. I have seen 14.5 a couple times. This is all off the overhead display which I have checked to be accurate within .2mpg on my rig.
Old 08-31-2015, 08:06 AM
WE3ZS's Avatar
WE3ZS
WE3ZS is online now
World Famous Mod
'05 2 valve V-10 EX 4R100 4.88s (with 35" tires for a 4.39 effective ratio) Banks headers 5Star tunes (87 & 89 Performance tunes used for all towing) 4" lift pulling a '14 Jayco Eagle Premier 338RETS at 11,000lbs 41' long using a Hensley Arrow hitch. I tow at or within 5% of the posted speed limit and average from 8 to 9.25 MPG depending on weather and terrain pulling all over the Eastern states and New England.
Our little wagon and camper.
  #28
Old 06-27-2016, 06:57 AM
FordmanNJ's Avatar
FordmanNJ
FordmanNJ is offline
Hi There. Yeah I just realized a necrothread a post over a year old regarding a 7.3 Diesel engine. What does this mean? Well the grey matter between the ears was not functioning fully and I meant to reply to a thread pertaining mileage of a 6.2 Gas not a 7.3 diesel. On top of this, I was using the phone and thought I clicked on the thread in which it was suppose to be replied too. Back to your regularly scheduled programming....
  #29
Old 06-27-2016, 08:56 AM
BPofMD's Avatar
BPofMD
BPofMD is offline
Received 1,101 Likes on 1,001 Posts
The way I figure it, when the gauge reads 1/4 I stop and fill up. It doesn't make a hill of beans how far I went since the last fill-up! What am I gonna do about it? I sure ain't gonna quit pullin' the 5er! I sure didn't buy this rig to talk about mileage bragging rights!!
  #30
Old 06-27-2016, 09:03 AM
RV_Tech's Avatar
RV_Tech
RV_Tech is offline
More wind resistance as speed increases.
I am in the same boat regarding mileage. I do loosely track it as a rough indicator of how my truck is doing, but losing sleep over small differences is not on my calendar.
Steve
Quick Reply: Towing MPG comparison
