So I bought a truck...
That maybe a ford only part. If you cant wait for an online order from riff raff. I would disconnect the hose and go to my closest hydraulic store and have them make you a line. Even NAPA stores can make hydraulic lines with fittings and all.
Glad to hear you're up and running again. Breaking down on the way home with the truck is a nightmare. I went and picked mine up down south and had a whole cache of extra parts with me "just in case". Turns out all I had to do was chase down an electrical gremlin with the turn/stop lamps before we left to come home with it and it ran like atop all the way home from Valdosta. Had me sweating bullets for the first hour or so though. Man, this thing has come a long way since then....
Could be anywhere up top, there are several places a leak could occur.
I would get those codes checked on the trans. You need to take it to Ford, or a Trans shop to get the codes read. Its anyone's guess otherwise. Parts store scanners can not read the codes in the trans.
Edit: Check the lines going to the back of the heads, there are o-rings that go bad there and can cause a leak.
#29
Lots of spots for fuel leaks down the back. Things can pool in the valley of the motor and then run down the bell housing. I'd check the fuel bowl first.
Blinking OD light means there's a stored code for the transmission. It can't be read by cheap scanners or parts stores. You'll need to take it to a good shop to read them.
Edit: Thomas is faster than me!
