Where to have my HPOP rebuilt?
Are there different levels of HPOPs? If a stock 17* HPOP is just a little weak for stage 1 or 2 injectors, is there something between it and a full blown HPOP that will support stage 3?
Doesn't make sense to power a pump that can power injectors much bigger than ever planned. Or, does a big daddy pump take as much HP to turn for the same output of PSI as a smaller pump?
My T500 fed my Rosewood 160/30's (stage 1.5) just fine. Never had a single issue, even on the 140hp setting on my TS chip.
I honestly cannot remember anybody that I've ever talked to that wasn't fully pleased with their Adrenaline.
IMO just make sure you really need that kind of volume.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
Mostly the ol t-500 is good...just thinking that may be better without the cha ching of duals...
I hear what you are saying Jim. I technically shouldn't need one with just stage ones, but towing 17k in my 140 tune put too much of a demand on the T500. Adrenaline keeps up fine. I don't care whatsoever if my oil breaks down faster. I run shaeffers oil, and if I'm lucky put 3k on it in a year, and it gets changed every year. Even if I did drive more, and the oil broke down faster, I'd just change it more often. That doesn't bother me at all, as long as I keep that 1211 away I'm happy.
Aaron, I'm sure the adrenaline would help you some, but you got some pretty big injectors there... That's what happens when you go big. Everything else has to be big to support them!
Yep, sounds familiar, except for the meltdown part, thankfully. My experiences are: T500 did real good, just wouldn't keep up in the 100 or 140 tune towing, would set the ol' 1211. HBJ, well I set a 1211 at will, with no trailer on, even after being sent in twice to be "upgraded" once and tested once and told it was fine both times. Had bucking at the top of hills with the T500 too, but I've came to the conclusion that was the res running dry. With the riffraff res addition that problem is gone too.
#28
#30
