Rear Axle Question ... 9 inch v 8.8 inch
#46
My 54 had an open 9 inch with 2.91 gears and it would just spin one tire on wet pavement. I looked at putting a detroit true trac in it but it does not work with gears less than 3.25 because the ring gear is the wrong size and I didn't want to get into the extra cost or work to change out the ring and pinion. My front had 5 on 4.5 so I swapped in a 98 explorer 8.8 with 3.73 posi and disk brakes.
#47
#49
Got my 9" housing under the 55 F100 and bolted down. Problem I have is the pinion angle looks like it will be way off. Looking for someone who has put a 9" out of a 72 F100 into the older (55) trk. Question is does the mounting pads have to be moved because of the angle in most cases or do they mostly match up ok?
#50
#51
Read the article, but have a question.
Hey Jeff,
Here is an article that goes through the rear axle solutions with some thoughts on each.
1948 through 1960 Ford F-1 and F-100 Rear Axle (differential) Swaps - Ford-Trucks.com
Ben in Austin
1950 F1
Ben in Austin
1950 F1
#52
Hey MT Trooper,
Welcome aboard! Show us some pics of your truck when you get a chance. It would be nice to
see what you are working on up there in Montana. I personally don't think it matters what engine/trans
you are running when choosing your 9 inch rear end. Other's will chime in with their thoughts & opinions.
When we got our 8.8 Explorer axle from a salvage place we also got the emergency brake set up
that went with that axle. We didn't have one & that Explorer one has worked out real well for us.
Ben in Austin
1950 F1
Ben in Austin
1950 F1
#53
Hey MT Trooper,
Ben in Austin
1950 F1
Ben in Austin
1950 F1
#54
Trooper, welcome to FTE the best Ford truck Forum on the world wide web!
Start a build thread and include some history and pics of your truck when you get the hang of it. There is a sticky thread, which always stays at the top of the 48-56 forum, which explains how to post pics.
Is your truck a 3 speed on the column or 4 on the floor with first being a granny gear?
#55
#56
The granny gear was made for things just what you described. On the farm my Dad would put his 48 Check 3/4 ton in 1st gear and pull out the hand throttle a bit as we would walk along side and pick corn or in the spring after plowing, picking rocks. When I was wee little I'd sit behind the wheel and steer and push the clutch in when told to.
#57
#58
Received 4,135 Likes
on
https://www.ford-trucks.com/forums/forum41/
#59
Hey Bryan,
That's a nice looking solid truck! I can't believe you guys already have snow on the
ground up there.... uggh…..
We are running 3.73 rear gears but we have a much different engine/trans set up.
We need to get others who are more stock to chime in what gearing would work best.
Ben in Austin
1950 F1
Ben in Austin
1950 F1
hail destroyer
02-15-2018 06:06 PM
Pearlwhite94
01-09-2015 03:53 PM
effie1
07-06-2005 11:44 AM
chris_p04
09-24-2003 08:43 AM
