Truck stalls out after running for a while
Both of the previous posts illustrate my point......TROUBLESHOOT the problem first. You are losing spark or fuel. The RARE third root cause is the oxygen has escaped the atmosphere where the OP lives.
Quit tossing parts at the problem, determine the root cause then proceed accordingly.
Eliminate each link in the chain until you find the broken one.[/QUOTE]
Until the OP determines what is dropping out it's pointless to introduce more variables by blindly replacing parts.
Simple basic troubleshooting will tell you where to go. Spark or fuel plain and simple. I stand by my statement.
on
Took the duel tank valve off to day on my 88 and filter wasnt in it and trashy gas and looks to be black grainy seiment the valves were screwed I order a new one ...but my back tank hasn't worked right since I had it and replaced tank and pump sending unit and strainer
Simple basic troubleshooting will yell you where to go. Spark or fuel plain and simple. I stand by my statement.[/QUOTE]
I will make the truck act up again and test for spark and fuel but I won't be able to get to it till Monday. I know I shouldn't be just throwing parts at it but I when I checked before everything was their again though I will reproduce the problem and make it act up to see what is going on.
I would think it is fuel if the pumps are kicking in and out right before it dies I don't see how spark could cause pumps to kick in and out.
Trav
Therein lies the key here, what is the root cause. Focus on the missing component, then proceed accordingly.
Not all of the trucks got filters in the dual tank valve.
Trav[/QUOTE]
Mine was suppose to have a filter ....Anyways im back up and running after replace tank valve ....it was all funked up no cleaning it
on
Well I got rid of the TPS Code but haven't had time to test drive it.
Turns out I didn't install the TPS correctly as the blade wasn't grabbing the TPS.
I let it run for 30-45 minutes and it didn't die like it usually would but only test driving it will know and I won't be able to test drive it till maybe Monday.
When I go on the test drive I will be prepared with tools to check for spark if it breaks down.
Trav
Trav
on
Took her for a test drive and knew right away she was going to leave me stranded.
Their was absolutely no power I had it almost floored to do 50mph.
Got to the local gas station regardless and put some gas in her and fired her up put her in gear and she died. Right then she started acting up again. Using my knife (forgot a screwdriver) I verified their was spark trust me my arm still can feel the spark.
I also checked the stream that came out of the Schrader valve on the fuel rail and it was strong like usual but it was while the truck was off.
Once I towed the truck back home I was able to drive the truck into its parking spot and I checked fuel pressure KOEF (key on engine off) and I got 37psi of pressure with no signs of leakage. I did not do a key on engine running test as I couldn't find the specs for it in my book.
I also checked vacuum to the EGR valve and Fuel pressure regulator and they both were within spec minus the EGR Valve would only get vacuum for a few seconds then turn off (probably because of the solenoid not letting it pass through).
I do have a few questions that I am wondering may pertain to this issue:
Once the truck is running are the fuel pumps suppose to keep running? When I turn it to key on engine off it will prime then shut off but once I start the truck they never stop running.
The truck feels a lot warmer then any of my other ford trucks with a 302 or 351 but the gauge is showing that it is fine? Could their be a part causing it to not start because of it being to hot? Also my coolant level seems to raise a lot when it has started acting up.
Could fuel injectors be causing the issue?
My rear tank and pump are for a 90+ truck and do not work could it be acting up? My front tank is correct but the rear I have the wrong one.
I do not know the exact fuel pressure when it starts acting up however as of right now it feels like a loss of power like crazy ( I know 302s don't have much power but I shouldn't need it floored to do 50 on flat ground and no winds out.
Any more ideas are greatly appreciated I am really missing driving this truck and I need another 4x4 for winter.
Trav
Trav
#28
Since you have enough spark to shock you I would suggest getting a handle on the fuel pressure. I am not certain what effects you triggered by using the wrong rear tank/pump assembly. That one now has a high pressure pump in it that may overwhelm the Dual Function Fuel Reservoir if you ever try to use it.
#29
on
It dosen't even turn on. What should I start first on for the fuel pressure.
If the DFFR is bad could that cause my issues?
Should I just disconnect the wiring to the rear tank?
I have already replaced the FPR, fuel pumps, 2 of the fuel lines because I put a hole in them, fuel filter, and cleaned the fuel lines I am not sure what much more I could fix?
Trav
Trav
#30
Stop throwing parts at the problem, diagnose the issue. Measure the pressure with the truck running. Should be ~30-35 PSI at idle w/vacuum on the FPR. The pressure should rise to ~40 PSI as you increase throttle/load. If those specs are met then go back to verifying spark by color and base timing.
