Problems with my 1995 F250 cooling system
Old 07-06-2015, 06:17 PM
Leggeman01's Avatar
Leggeman01
Leggeman01 is offline
Hi all, I am having some issues with my 1995 F250 RWD 5.8l truck. I did a thermostat swap and coolant flush a month ago. The truck runs well but will start to climb up on the temp gauge then all the sudden, wham, the temp goes to normal. I got a little worried so I did a water pump replace and replaced the thermostat with a motorcraft 195 degree unit plus another coolant flush. I let it set to leave all the air bubbles come up too. This morning the same thing except the temp seems to be lower after the "wham". I am going to replace the fan clutch this week when I can and hope this takes care of it. Any other suggestions?
Old 07-06-2015, 06:40 PM
mrollings53's Avatar
mrollings53
mrollings53 is offline
It's your thermostat sticking closed. As long as the needle is still in the NORMAL range then you're good.
I replaced the water pump, radiator, t-stat, hoses, etc. on my '95 460. The impeller on the old pump was completely rusted away. Thus all of that steel is dissolved and embedded in the motor. I've flushed the coolant three times since I put the new pump in, and the coolant still looks like mud. Over time the mud has caked onto the t-stat; causing the same symptoms you have.
MurderMode
09-23-2017 04:47 PM
orange57
1997-2006 Expedition & Navigator
07-30-2016 04:11 AM
maxine
07-21-2015 12:27 AM
MR STACK
35
12-28-2008 02:37 PM
mikeinarizona
02-21-2005 11:13 AM
Quick Reply: Problems with my 1995 F250 cooling system
