Gooseneck ball stuck!
Hi guys, I recently bought an 05 F-350 SRW and it has a Blue Ox hitch Blue Ox Diamond Hitch - Underbed Gooseneck Trailer Hitch - 30,000 lbs Blue Ox Gooseneck DH1201. Problem is that I can't get the hitch released to invert it. I've tried cleaning the years of caked on mud, hammered the crap out of the release pin, soaked it in PB Blaster, heated it with a torch, and still can't get that damn pin to release so I can rotate the ball and invert that sucker! Does anyone have any suggestions? I won't be towing with the gooseneck a ton, but I don't want to remove the hitch completely.
I don't know how accessable stuff is under your bed, but if you can get at things with an air chisel with a short, blunt shank in it, the vibration generated by that just might break things loose. Just hold the blunt point against the side of the ball socket under the bed, or maybe even from within the bed from above.......probably worth a try.
gizzmolink
1999 to 2016 Super Duty
07-12-2008 11:59 PM
Big tmiller
Fifth Wheel & Gooseneck RV Towing
11-19-2007 12:48 PM
afreemanmd
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
23
05-29-2007 10:50 PM
