Restoring and Rebuilding A Bayliner Cierra 2651
#76
Looks beefy!
I am shocked SHOCKED! that my pontoon is rated for a 90hp motor with just a sheet of 3/16" aluminum plate and a couple pieces of plywood bolted to it. This whole deal is held to the boat by 4 3/8" bolts...
I will be sticking a 115hp+ on it at some point though. After I do some work obviously.
#77
Looks beefy!
#78
#79
#82
Sorry I missed your post.
Decided to cap the she with aluminum as well and had a family member do the welding today - my welding skills are new at best, and aluminum is a bit of a trick to do well I hear.
I used the template to drill the outboard mount holes after this picture. Will begin building the splash well on Monday I think since it's a holiday.
Cheers,
Nate
Cheers,
Nate
#83
#87
#88
#89
Originally Posted by LivingLarge
Good job Nate, don't forget to pack your life vest.
Originally Posted by Snowseeker
Is that glass or acrylic?
Looking good! Will it have an on board gas tank yet or portable tanks?
It has quite a large inboard tank that was there to feed the previous thirsty 350. Don't know the size yet, will figure it out once I run a bit of gas through it.
I'm willing to bet your Honda that on that boat it's an in board tank
I wouldn't take that bet because I am leaning that way too
So I spent the week hand sanding - shoot me. Finished the morning... I do not envy the life of a body man.
The hours and hours of sanding were worth it though after the paint guy did his work. I love the outcome. Can't wait to peel off the tape and put the stainless accessories back on. I think it should look really good for the sort of budget project it is.
Should be working on getting the motor on tomorrow night.
Cheers,
Nate
#90
Took tape off and reinstalled accessories. Put the canvass up just for a test fit- I hate the look of canvasses up - they make boats look goofy in my opinion. Ruin any sort of sporty look. It will only ever be up in a rain situation.
Also dropped the motor on - the new transom didn't even flinch.
I really like the way the wood slats turned out against the metallic blue. I think they will look good up front once I finish them.
