Oil in coolant
Glad you got the issue figured out. Trains quick connect fittings were a pain on my radiator swap also.
I'm curious about something you mentioned in PM and someone here will likely know. Has anyone had a leaking oil cooler in a truck with red ELC coolant? If so, does the milkshake look a normal brown/tan color or does it pick up some of the red color and turn pink?
Weii I'm back, oredered another radiator. It came in yesterday afternoon, and yes we had to do a little modifying on the connections, but its working now.
As for the milkshake, mine was pink when hot and slowly turned slightly browner as it cooled and started to separate.
As for trans fluid, I went to Ford dealer they sold me Mercon V, said it would work. Now you have me wondering if I should use Valvoline Max life to do a quick drain and fill on the pan. I was planning to do this this afternoon after I finish the Simple Green flushing.
#29
