Idle flucuation problem
1993 F-150 5.0L 302 V-8 4x4 with Automatic trans.
My Truck runs okay at first but after driving and when it warms up, this problem occurs.
After I stop and shift from Drive to Park or Reverse, the idle fluctuates up & down between 450rpm and 1000. Sometimes after fluctuating for about 20sec it steadies out nice and smooth other times it continues until I hit the gas to rev it up. Occasionally it will stall out after shifting from Drive to Park and/or Rervse.
Do you know what may be causing the idle to perform this way and I what should check to correct the problem.
You guys rule!!!!!!!!!!
The ISC is the IAC which is exactly the cure for the idle surging I've been dealing with for quite a while.
IAC did not show up on the Error Codes from the dealers mechanics.
They had a lot of ideas as to what it could have been, but you guys nailed it- thanks.
ps
the old one was stuck, so I ran 12 volts across it and it clicked and then shorted out- oh well.
ps
>When you replace it, do you replace the entire value or just
>the BPA-IAC?
>'93 F-150 loaded and modified!
>Check my Gallery
Good question..
I have an intermittent surging problem with my '96 Windstar that the mechanic can't figure out.
It was suggested that the IAC was the culprit by an online service tech that has dealt with several 3.8 liter similarities.
The do-it-yourself guides at the auto parts store indicate that (at least for my vehicle) ya can't do it yourself because it has to be calibrated.....
I wish you the best (though I know this doesn't really help).
beaming1
>the BPA-IAC?
>Check my Gallery
Good question..
beaming1
I tried all of the "cheap" fixes, to no avail, on my '93 Aerostar before I repaced the valve(~$80)(I think Ford calls it the Idle Air Bypass Valve). In any case, it is what some call the IAC (Idle Air Control) valve. Once I replaced the valve my Aerostar ran smooth as silk. It is super simple to replace. As far as I know, there is no calibration required for this valve. The TPS(trottle position sensor), on the other hand would need calibration if replaced.
swalker1522
11-25-2014 10:46 AM
mb5518
1983 - 2012 Ranger & B-Series
09-17-2014 07:12 AM
