Rusty 2010 F-150 Lariat
#32
Double check for perforation. That is all Ford Warranty will cover. Unless it is rusted through, they won't help out. That is how mine started as well.
#33
Crystal
#34
Last night I got a photo of the root cause for my rust. You can see a rubber drain line. It should have been installed to end up where the finger is pointing and therefore direct the water to the drain. Instead, it was placed between the inner and outer rocker. So water would fill up there until it got high enough to flow through the hole. To add to the issue, if you park on an incline, the water would pool in the corner and never reach the drain!!!
#35
#36
I stopped at a dealer on my way home from work today. Service advisor looked at it, and said Ford won't do anything, until the metal is perforated. So it looks like I'm on my own, for now. It is just starting to show some small bubbles. This is the lower rocker panel, under the passenger side rear door. I'll crawl under it this weekend, and do some evaluating.
#38
...Thanks, Crystal!
Crystal
#39
#40
#41
I beginning to think that Ford has a problem with rust, especially in the rocker panels. My 2010 F150XLT SCAB had rust issues starting a couple of years ago. I took it to the dealer about a year ago for especially for bubbling paint inside the DS back door, but it wasn't rusted through so they wouldn't do anything. Now, a year later, it's rusty enough on the underside of the rockers that I was able to push my finger right through.
I even went the route of spraying the undercarriage with Fluid Film before the last 3 winters.
I am really disgusted as this truck has only about 51,000 miles on it. My previous f150 was 15 years old with 140,000 miles and it was in better shape than this when I sold it to buy this. I have an 08 Subaru with that looks practically brand new, even underneath there is no rust at all. If Subaru can do it, why can't Ford?
#42
I beginning to think that Ford has a problem with rust, especially in the rocker panels. My 2010 F150XLT SCAB had rust issues starting a couple of years ago. I took it to the dealer about a year ago for especially for bubbling paint inside the DS back door, but it wasn't rusted through so they wouldn't do anything. Now, a year later, it's rusty enough on the underside of the rockers that I was able to push my finger right through...
If you haven't already, I'd recommend returning to the dealership so they can check out the rust now that it has become more severe. Once they've taken a look, I'll be able to research some ways to help. Keep us in the loop.
Crystal
#43
Thanks Crystal for being supportive. I am really disgusted with the whole problem and was considering just selling it. It is out out the 5 year rust through warranty, so I figure that they won't look into it, even though I did try to get it fixed before the warranty was up. I will let you know when I can make an appointment to have it looked at, but it might be next week before I have the time.
#45
Crystal
