2015 F350 6.2 Tire Sensor/ Speedo Recal Help
I have a 2015 F350 6.2 with 37's, lift.....
I need to reset the Speedo and Tire Sensors.
What are my options?
Does a 5 Star fix this? Not looking for a engine programmer but if it all comes in a package than....
I called Hyptertech and they just have the speedo fix and it's a module that stays behind the dash and they stated that they DO NOT have anything to fix the tire sensors yet.
Thank you for your help.
I have the same truck as you, 6.2L, 6" Lift and 37" tires. There is no programmer out there that will change the speedo readout. The only way to go is the HyperTech module. I put one in mine, programmed it via the USB cable with my laptop and the program and my speedo is less than 1mph off at 80mph. Speedo reads 80, GPS says 79.7.
I also have the 5star tune, which helps move the transmission shift points to the proper speeds and RPMs.
It's a good combination, and would recommend it. I've had it in my truck for over 18months with no issues.
As far as the TPMS, mine had no issues reading, other than the tire pressures being below the E load range of the factory tires. I went to my local Ford dealer and they lowered the threshold for me at no charge.
Hope this helps.
Hope this helps.
jlmotox
1999 to 2016 Super Duty
07-19-2014 12:54 AM
NewFordOwner
13
01-05-2005 12:40 PM
