Modded C's Installed today!!
So today I had the Modded C's installed. (Thank you Junior @ ATS for hooking me up with the springs & hardware!)
I had already done the V's up front. Now I think I'm having buyers remorse on not getting the X's. I think I need to raise the front a bit. Opinions and ideas please...
Ex looks great, I must say that I'm surprised you didn't go with the X codes with that big plow. But as noted by others the hangers or shackle have good results and won't change the ride you have now if your happy with the feel of the V codes. I also did V codes on my previous Ex and really liked the ride.
Thank you for all your replies....and so fast!!
The reason I didn't go with the X's was multifaceted. I fell short on my research to begin with...and found bad info that labeled the 2630# (per side) springs as X. I realized the error after the truck was at the spring shop. They gave me a lot of push back when I called and asked about the X's. Super nice guys...They are just not a shop that does modifications and were hesitant to do the V's to begin with. (I think it was a liability thing as well as customer care.) They kept telling me that if the ride is too harsh and wanted them changed out for the Excursion springs it's on me. Second thought I had was more about $$. Maybe I wouldn't have to do anything to the rears? Well to spite the DW chirpalating in my ear about the $$ spent...here I am with V's up front and Modded C's on the rear.
Money being no object..I would throw the X's on it and be done..but alas it is!
As far as the rake I am concerned about the additional drop with the plow. They stand up pretty well as you can see from the other pics I had posted..but there is a drop. But one thing at a time. (Plow is barricaded by my trailer and my Dad's trailer for the time being, so I cannot check that just yet.)
So on to leveling the Beast....
Question 1: If I do the shackles, do I have to do the front and rear of the front springs or just the rear where the factory shackle is mounted currently? I am thinking if I go this route I will be able to do this with a friend. (Due to back surgeries and a fusion I won't go it alone. The sway bar, the front bearings and brakes all around kick me in the nads!)
Question 2: Add a leaf....probably not for me to do..but would this be a way to gain the 1.5" to 2" I am looking for, at the same time boosting my front spring capacity...close to if not at the X's?
Thanks again all...I really appreciate it!!!
Keith
Keith
Keith - Im not the expert here, but I do a lot of due diligence before each investment. What the pros have told me and some on here is you only need to do the front with the lift shackle and very economical. I am 1.5" lower in front and will add a 1" shackle that my shop will install in a few weeks when I am out of town. Your truck looks good !
That's my initial gut feel too.(Shackles) I will have to measure on better ground, my first measurements were like 39.5 front and about 42" rear. (ground to wheel well.) I will also do center of hub to wheel well for comparison another comparison.
Thank you for your input!
I was just looking at some shackles. They are saying 45 min for install...I liked the sound of that! That's something that could be done trial and error.
I like my emoticons to have noses. Lol. I have noticed FTE doesn't like them I will try to make sure to leave the nose out
