'77 F-250 4X4 351M build is a dog- swap a 460 ?
#31
My 77 F250 4x4 was a 400 2V truck and I am very happy that the minor oversight by Ford has been corrected. I have a 460 with a mild build and getting a little less mild here in a couple weeks. That being said, just pray that gas prices stay lower than they have been. 460's like fuel. I don't tow but I occasionally haul stuff in mine. I had almost 2 yards of dense soil in it last week. I don't know the weight but is squatted the rear just a bit. The 460 didn't even know I had a load in the truck. The only difference felt was the truck rode better and the steering was much lighter! LOL
I'd go 460 but then that is always my canned response. The motor was made for what you want to do with it, period. No issues with the 2V vs 4V cause most 429's/ 460's were stock 4V. (MOST) (MOST) (MOST) Did I mention MOST for all the corrections that I am sure are to come?
#33
Just my two cents and experience.
I've got a 400 6.6 and its a damn good engine. Unfortunately ford released it a bad time. Government emission regulations at the time really dampened this engines capabilities. You can really sqeeze some *** out of the 400, it just takes a bit. The easiest things are a cam ( I'd recommend comp cams) new carb ( holly or edlebrock -I have a holly), intake manifold, and exhaust. If you really want some ponnies you can put some 351c heads on it and Keith black flat top pistions.
#34
#35
#37
well after doing some digging on the 'net, ive found CARB/EO approved headers(Hedman long tubes), and the 'Brock 4 bbl intake. looks like i'll be doing the headers first (after they're ceramic coated first of course). thanks for all the info and help guys! Maybe theres hope for this anemic 351M after all !
#38
I really don't think there is...simply not enough cubic inches to "get by" with basic performance bolt-ons to get an adequate power plant for a 5000lb truck that will see occasionally tow use.
I really think you should spend the money on a better engine to start with, considering your intended use.
Feel free to post before and after dyno results for us though.
#39
'clever-
i tow maybe 10 times a year(my snowmobiles). i think with a header install and a better flowing intake 4 bbl manifold along with a 600 'brock carb i'll get the improvements i need. someone chimed in earlier and stated stock the 351M was grossly rated at 134 hp. What the heck was Ford thinking ??? Good grief! if i can squeeze more torque out of it i will be good to go, plus another mpg or two would be nice. my truck holds about 48 gallons of fuel when full, be nice to have it last longer than 450 miles.
#40
I have heard horror stories of 460's getting 5mpg!
But these trucks were around when gasoline was what, 0.45 a gallon (guessing) My 351m supercab stays PARKED most of the time while I run my little mouse 302 66
Picked up a 400 79 dually not long ago.. My combined MPG's are plummeting so I think my next will be a diesel VW bug!
#41
#42
well after changing the cam timing to straight up (from 4* advanced) its still a pig. i went to the machine shop i deal with and we dug out a newer 400 block(with the build date code past the 3/77 bad casting) the cylinders were standard bore, and they have a 400 crank on the rack that has been cut .010"/.010" it just needs to be polished. also dug out 12 D1AE con rods for it. the cylinder head guy has a set of 351/400 heads that are ready for refreshening. gonna do some 7/16 screw in studs with roller rockers. comp cams make a decent roller cam i like (#32-421-8) for a roller conversion to roller hydraulic. havent decided on pistons yet but will probably be around 9:1 with a +.030" or +.040" oversize bore. should come out to be around a 406-408 CID
i have had enough of 8 mpg and 134 hp. looking for 275~300 and 12 mpg.
anybody build a mild 400 and what did you get for hp & torque ?
#43
#44
Ok - I will go there...
I told you so!
Make sure the pistons you get have a taller compression height to get the piston top flush to the deck.
I had a 400 with cheap summit cam, heads decked .030 (pistons still down in the hole), cheap in the frame headers, performer intake, holley 750 DP, and I tuned it on a chassis dyno to 240rwhp/355rwtq.
Same day we tuned my buddy's 416FE with iron CJ heads, 10:1, headers, rpm intake, holley 750, and way more cam - his made 275rwhp/400 rwtq.
I was pretty pleased with that 400 for what it was.
BTW those are mustany dyno numbers and not dyno jet, which is about 10% lower. I figured that 400 was about 350-375bhp.
#45
I built a 400 back in 85 for a 79 4x4 I had. My cousin had a 76 4x4 with a 390 (and it was really a 390 he built and put in.) My 408 would pull him off the line on the road and it "felt" significantly stronger than his. We never hooked them together to see which one would pull the other but I have no doubt mine would have prevailed.
