96 F250 7.3 Auto, wondering how well itll pull.
#196
Its a 3" 45, I did start having some issues right after I installed that one. (However I installed multiple things at once at that time. Like an egt gauge) Ill go find a 4" 45 street pipe and cut one end off/shave it down and see what that does.
#198
So for anyone wondering, no the 6.0 and SD 7.3 intercooler tubes and e99 spyder is not an "easy" install. Just taking off the front header support is an adventure. The passenger side 7.3 tube is very hard to get in there and u have to figure out how to re-route some of your cables/hoses/tubes. The front bumper bracket makes it hard to get the 6.0 intercooler in there and be able to move it properly. You have to cut away some of your front core support. The e99 you still have to either drill&tap&plug or weld the holes shut. Then once you get your intercooler in the right spot your have to build brackets that accept the intercooler, and the 6.0 tranny cooler inside of the front grill. If your gonna do an intercooler, just buy a kit. Its worth it. I already screwed up and broke my front header support bracket and I cut my 12" long cooler tube too short. So Im waiting for more to come in. Yayy ford, only you could make a front header support that takes a contortionist to take it out.
#199
#201
I am using SD steel pipes and all aluminum intercooler and had to add 2" to the pipes at specific locations. The core support does get cut to run the pipe through but it all seemed a lot easier than turboing and inter cooling a new nissan 350z.
Put some photos up and ask a few questions... We all like to help a fellow out.
#202
#204
So, are you saying your SD pipes didn't bolt in? Did you have to weld anything? A couple other guys I talked to said stuff has to be fabbed. I keep getting different stories LOL I am finally getting an E99 spyder that someone else has and didn't use. Do you happen to have any pics?
Im having issues with whatever the T hose is that is coming out of the side of the passenger side of the motor. Anyone know what this is for?
Honestly Your better off selling that e99 for some profit, and buying the CX racing kit, and just putting a 6.0 cooler on the end of the cx racing kit. And selling the cx racing kit intercooler. Itll save you ALOT of headach for the amount of money your gonna spend for the DIY parts and pieces. Honestly DIY isnt worth it anymore, it was back when the old numbered members found them and moded them for $200 total. Even with the good deals Ive found Im still at $700 with everything. I wish I could just sell my setup for $600 and buy the cx racing kit. That being said, Im only a few brackets and 1 long tube away from being finished.
http://www.ebay.com/itm/99-00-01-02-03-FORD-F250-F350-SUPER-DUTY-INTERCOOLER-PIPING-PIPE-YC35-6C646-BA-/191418038271?hash=item2c916777ff&vxp=mtrhttp://www.ebay.com/itm/99-00-01-02-03-FORD-F250-F350-SUPER-DUTY-INTERCOOLER-PIPE-XC45-6C646-AB-/201205927298?hash=item2ed8cecd82&vxp=mtr
More pics of whats going on.
#205
#207
#208
I did, I modified the 4" 45 degree street elbow I had laying around. Thanks for the advice.
#210
