51 F3 239 head bolts
Intake is off
One head is cracked but machine shop welded, cleaned and milled.
Got new studs from Van Pelts.
Here are pic of the chest cavity. Gonna switch the revesred valves. Yep, opening that can of worms.
Any insight from the pics would be great!
Driver side. Gotta zoom in
Passenger side. Really gotta zoom in.
I have no experience with either Dennis C's or Summit's bolts. I have heard of problems with length but don't remember whose bolts they were.
On 8BA-style engines, leakage isn't as big a deal as the engines with studs, but most of the bolts are "wet" (go into the water jackets). I use copper anti-seize liberally on the head bolts, no leaks, and easy to remove. Lots of people prefer Permatex #2 non-hardening sealant, or the gold standard is GM p/n 012346004, a teflon-based sealant ($18 for 50cc's !!)
Jonathan, I usually paint the heads then paint the bolt heads after installation. The only rust that's a concern is in the threads or the shank under the head, and you don't want to paint those areas.
PS, Most of the flathead gurus on Ford Bard recommend backing down from the factory specs of 65 ft-lbs on the head bolt, to 55. The thin decks on these engines are a concern. With FelPro composition gaskets, no problems with sealing.
I torqued the bolts to the recommended 55 but am thinking about stepping it up to 65, as I am out of ideas.
Any suggestions?
You need to do at least two re-torques after getting it up to temperature. Keep doing it until they hold the 55.
I'm skeptical of welding heads. A good used head for an 8BA can be had for $10 most of the time, but shipping is a killer. But for all the work involved, a better solution than trying to weld cast iron.
PS was the head crack over #3?
The crack and weld were at 4. Top left corner at the firewall.
Not sure what was washing 3.
Gaskets are still on heads
Conclusion
I retorqued the heads after coming up to temperature two times and they held 55 lbs torque. Did one last time for good measure. Bubbles still there but very faint.
I cannot find where the bubbles are getting in. Oil looks good. Water does not smell like fuel.
Tested the cooling system and it held pressure. No leaks whilst running except at the cap. So I tightened cap and bent in the cap's ledge that hold onto radiator. No leaks at idle or while driving.
Gonna drive it for a whole and hope that the bubbles are just reminsce of multiple flushes and age. Thanks for all of the guidance and support.
Here are some pics:
Here are some pics:
#28
mytoolman
05-14-2019 01:59 PM
86fordtruck
04-11-2011 10:30 PM
jamies460
08-30-2007 02:04 AM
