Snowseekers V10 experience. "Chitty Deuce"
#241
Thanks guys! Sorry we can't talk selling or buying according to the rules.
Today I pulled all the brakes off. Very much to my surprise every single slider was lubed and moving freely! Both front calipers had locked up pistons in them. I could get one of the pistons to pop out but not the second in both calipers.
So new front calipers on the way.
The rears I got all 4 pistons to pop out however I cracked one. Checking around I couldn't get one very quick and they are almost as much as a whole caliper. So I made up my own in the lathe. I cleaned up the piston bores, cleaned the seals, and reassembled everything.
The discs all looked like they were replaced just before "the noise" happened. So there was plenty of meat on them to take a skim coat off and get rid of the rust pitting.
The pads had almost no wear on them as well. So again I blocked them flat and clean again and reused them.
I hope this V10 has more get up and go when the brakes aren't locked up.
#243
I hope to be able to have it completely assembled and totally driveable by this coming weekend. It would be ready to go by tomorrow after I get the brakes but I have to wait for a trans cooler that is coming yet and a radiator fan which is also on the way.
Also I am still waiting on the title. Apparently it is coming from a "car dealer" that had the X before the PO I got it from. I did talk with the guy when I went to his place to look around for a y-pipe and radiator fan. So I am confident the title will come and it will be ok.
#244
#248
I actually haven't been out the front door in awhile. I will have to take a look if it is out there.
I assume standard 3:73's but I would have to check to be sure. It wasn't like a complete slouch. I just expected the rear tires to spin some when floored from a stop, but the brakes were hot, tight, and stuff so I can't say anything yet till I get a real drive in.
I should wait to get fresh gas in it too. I hear the X was sitting at least 5 years from the owner before the PO. lol
After I get it driving I am taking it over to my buddies body shop for him to look at a couple spots to possibly be fixed and then strait to the detail shop for the full treatment LivingLarge style!
I already got the quote of full detail inside and out for $150. With all the years of crap on it and the size I feel it is totally worth it.
Any tips of getting "****" smell out of the heater? Not sure if it is from to much AC when it was running years ago or if something was living in it.
#249
As far as the ac vents, many of the better detail locations here have what looks to be a gun from the Jetsons. Since, I'm guilty of smoking an occasional Cuban cigar (windows open). I have them clean out the vents every couple months. Next time I'm there, I'll ask what's it called. I'm guessing it's some type of neutralizer.
#250
I do remember some talk at sometime about some sort of powder or something you would dump down the cowl and into the airbox and let sit for awhile and then blow out.
That could have all been an old wives tale though just to get powder all over inside the truck.
I thought maybe there was just some residue on the bottom of the airbox so I turned the hose on down the cowl for awhile but there was no change.
#251
#252
#254
I actually haven't been out the front door in awhile. I will have to take a look if it is out there. I assume standard 3:73's but I would have to check to be sure. It wasn't like a complete slouch. I just expected the rear tires to spin some when floored from a stop, but the brakes were hot, tight, and stuff so I can't say anything yet till I get a real drive in.
#255
haha, I hate the rat **** smell!
This isn't quite that rat **** smell though, it is more of that stale AC water smell.
Thanks for the offer Greg! I will see what I can get done with sprays and foggers and whatnots first.
Vwags, I will look into this stuff. What is the BG abbreviation for?
