'48 F1 - Home, First Drive, A few Questions
#46
#47
Ross, when checking the valve clearance with a feeler gauge, what is the secret to knowing when the tappets are adjusted correctly, barely squeezes in or just a little firm. I ask because I need to do the same thing to mine but not sure what it should feel like when adjusted correctly.
Jonathan
Jonathan
#48
OMG, they were SO far out, I'm surprised the engine ran as well as it did. At least 0.03 or more..some looked like they were about a 1/16" gap.
While it's not perfect now, and I'll probably do another pass at some point...on a relative scale the engine now purrs! I'll get a recording tomorrow for comparison purposes.
Highly recommend anyone doing this to buy two of the thinnest, shortest 1/2" open end wrenches you can find. Took me about 4 hours including pulling the wheel and access panel, but I was taking my time and had to stop for a break from time to time, plus stopped for supper in there as well.
View of the lifter covers from the access panel.
Here is a view of the valve stems/lifters. Are there any recommendations re: how to clean some of the sludge out of there?
I tried wiping it down, but almost impossible to get to and it's pretty caked and baked on.
#50
Jonathan
Jonathan
#51
I'll look and see if the counterweight is in place on the old manifold.
Also the down draft tube is clear.
#52
Jonathan
Jonathan
Congrats on getting 'er done!
#53
#54
#55
Here's the post valve adjustment video. Not the most exciting video on the internet, sorry no cats were included in the making of this video.
BTW Ross, yes I'm running an oil filter.
Post valve adjustment video
#56
#57
#58
Although I haven't had any issues with overheating, I did get a scare the other day. I was driving along and looked at the gauges and the temp gauge was pegged on hot. Slowed down and no difference, so pulled over and everything seemed to be running ok, so went straight home. Pulling the wire off the sending unit, I noticed it was fairly corroded, so cleaned up the connection and it's working fine again.
Ross, yes the vid was made parked on concrete, so I agree it makes the vid sound a bit more "rattle-y" than it does in real life.
#59
So...two steps forward, one back.
I rebuilt the carburetor and it really make the engine run a lot better. Previously, the accelerator pump wasn't working so the engine would almost die as you pressed on the accelerator pedal.
During the cleaning, not only was the accelerator pump passage clogged, but several others including the vacuum advance for the distributor.
Got that all working and drove it several times with it running very smooth. Then today I swapped out the fuel pump and changed the oil and oil filter. So far this seems to have fixed the gas in the oil issue..but I've only driven it 2.5 miles.
After swapping the fuel pump, it started great and ran well. Then took it for a drive and it started dying at stop signs. When I got back to the house, it was running rough and missing like crazy.
I'm assuming this is probably some crap that's now been flushed through into the carb and clogged it up again. The only other thing I did was put clean oil in the air cleaner, the old oil level was low and was filthy....it runs better without the cover on, but still not very well. I'm assuming that probably means the air cleaner is clogged as well.
I did slosh a small amount of oil onto the outside of the distributor cap, but wiped that all up and wiped off the spark plug wires.
Any thoughts before I pull the carb and flush it all out again (there is a filter in line going into the float bowl)?
