1993 f350 7.3 over heating
I have a 1993 f350 7.3 when I put a heavy load behind it, the coolant system will have so much pressure it blows the resovor cap of and will cause the truck to over heat. What can be causing the back pressure?? When I do not have a load I don't have any problems can drive it all day and will never over heat only with a load behind it??
Received 3,107 Likes
on
welcome to FTE.
first thing i would do is drain the coolant and flush out the radiator.
preferably removing the rad and flushing it in the bottom and out the top.
my bet is a partially clogged radiator.
this can easily be tested with an infrared thermostat. shoot various places across the radiator surface. it should be hot on top, and progressively cooler as you go down. if you find areas where it is hot all the way down, or almost all the way down and cool almost from the top down, those cool areas of the core are plugged and not working to dissipate heat.
this will cause the areas that are not clogged to not let the coolant cool properly, giving you an overheat condition under load.
Amish Ford
12-14-2016 07:41 PM
corksil
16
10-14-2015 08:15 AM
jlegge007
03-30-2007 09:33 PM
wannabronco
13
12-11-2004 03:47 PM
