carb for 1949 ford f1 6 cyl
You can rebuild it fairly cheap:
Holley 847 Carburetor Rebuild Kit (4080S) -
Here is a video of the rebuild (I didn't watch the whole thing for accuracy):
You should be able to get it running like new!
I cannot answer your direct question about substituting a modern carb.
However, if you successfully rebuilt your existing carb and the engine is not running well, a modern carb will not correct the underlying issue as the carb is not the issue.
To help other members here serve you, a better description if your engines symptoms would be helpful.
FORDF100SB
07-22-2019 03:52 PM
Victor Aguilar
11-09-2015 05:29 PM
