Towing and Dual Rear Wheels
To get the rating up over 18K you're going to need a diesel dually.
2015 Ford Super Duty | View Towing Specifications | Ford.com
When I went looking for a truck to pull my 8000 lb. trailer while having a 2000 lb. slide in camper in the bed, all I kept thinking about was if I used a single rear wheel F-350, what would happen if a tire blew out.
Dual wheels for the win.
I've seen it done, but that backhoe is heavy for a pickup under any kind of frequent use. 18k total sounds really light to me, and a quick Google search shows 17800 for a 4x4 ex hoe. Even an orops 2wd will probably push 16k. Any tandem dual goose I've ever seen weighs in around 7-8k with a 20 or 22k GVWR. So you really should be looking for a trailer in the 24k range, and the truck to pull it, which I'd have to say bare minimum f 450 pickup. No way SRW.
It's a 1998 4X4 and is listed at not greater than 16000 in my book extendahoe but no 4way bucket. I dont know what a trailer to pull it weights empty but I'm guessing 3000 lbs itself. I've got my question answered so everyone thanks for the help and links.
Oh, just saw you said trailer would be more like 8Klbs that changes things..maybe this will be a better job for a dump truck and not my daily driver.
Big Tex Trailers 25GN HD Tandem Dual Axle Gooseneck | Big Tex Trailers
About the smallest trailer you'd want would be a 25' gooseneck with 12K axles. The one in the link above weighs 7,250 lbs. That puts you around 23,000 lbs total weight which is a LOT for a pickup truck. It's in range of a newer DRW F350, but not by much.
I'd agree with this if you have a dump truck available. You'll probably need the dump on the job with the machine anyway.
1968F250LWB
02-03-2003 07:57 PM
