'01 F-350 Loud injector chatter?
One side down, One to go
This is No. 1 injector
This is No. 5 injector
Somebody obviously didn't know about the 50 cent fix!
I got one side finished today. Ran out of daylight. Going to tackle the other side in the morning. Glad I decided to go ahead and replace the O-rings. The lower ring on No. 1 and No. 5 were in terrible shape. Somebody had obliviously been in there before. They tried (without success) to zip tie the plug together. You can see it isn't plugged in all the way. It has George safely tucked under it now. Went ahead and replaced the glow plugs also while I had it apart. Can't wait to get the other side finished to see if it helps. Thanks for all the advice guys!
I bought Motorcraft glow plugs.
I also bought Mobile One synthetic 5w-40 turbo diesel engine oil and a mobile one oil filter. I hope this will help also. After all the parts I bought, the oil and filter was the most expensive.
How many miles on your injectors? Mine has 185,000 on them. I think I'm probably getting air in my fuel also. I am going to be doing the hutch mod soon. I hope this will solve my problem.
on
Also, depending upon how strong your LPOP is, you may want to put the VC's on with two bolts holding each down to contain the oil that the injectors are spitting out.
Put rags over the GP holes when you turn it over by hand for the first turn and turn very slowly. If you don't, you'll be surprised by how much oil and fuel come out and it is under a lot of pressure.
Your not kidding! Put a rag over them and turned the engine slowly with a breaker bar, and all of a sudden it sounded like I had turned on a faucet for a quick second. Blew the rag out and on the ground! That's a lot of pressure!
Injectors back in and torqued. Found a few rocker hold downs that were about 1/4 turn from being torqued. Engine cylinders blown out. New glow plugs installed. Everything plugged in. George resting safely behind the plug. Rain !
Never fails. Almost finished and it rains.
169,200. Good point about air. Wouldn't the FRX handle that though? Is the hutch mod dropping the tank?
Yes. The hutch mod is removing the fuel tank and doing away with the in tank filters and re-routing the return line away from the sump. Most people add in a before pump filter also.
I see that now. Your referring to the blade in the upper left of the picture I assume. Anybody know where a good place to get a new wheel is? Besides the dealer?
#30
you do not need a new compressor wheel. if the nicks (i see 3) bother you, you could blend them with a file to remove stress risers.
frdf250
05-03-2017 06:11 AM
wranglerdude
Computer Chips & Tuners
02-03-2006 06:16 PM
