Please Help, new to me farm truck won't start.
Still slow to start, 10-15 seconds of cranking. When it finally does it sounds very weak for about 2-3 seconds then sounds like every other 7.3 idle. Same as with it plugged in, only difference is that the service engine light is on if the icp isn't plugged in.
Doesn't sound like your ICP sensor. The light coming on with the sensor unplugged is the code for the sensor being unplugged. Not real sure what other data you're going to get from a code reader unless it can read live codes like the oil pressure coming from the HPOP.
Got access to any hydraulic gauges and fittings? You can make a mechanical gauge to check the HPOP if you've got a 3,000 psi or more gauge, some hydraulic hose and some fittings.
If you've got a long weekend available, you could also swap the HPOP from the other truck in to rule things out. Just be sure to order new fuel line sleeves for the fuel bowl for both trucks and have some RTV on hand for putting things back together.
That's what I was thinking. I do think that I should replace ICP sensor, but the sensor and pig tail is going to run $200 from riffraff. All reviews indicate that it's a fair price and a quality product, but money is tight. I really need to spend my cash getting this beast running well. I just ordered these products as diagnostic tools:
http://www.ebay.com/itm/10-1-Quad-Core-Google-Android-4-4-Bluetooth-HDMI-CAMERA-Mid-Tablet-PC-8GB-1GB-/111647838762?pt=LH_DefaultDomain_0&hash=item19febad22a
http://www.ebay.com/itm/Car-Vehicle-Mount-Windshield-Dash-Holder-for-LG-G-Pad-7-0-8-3-10-1-inches-/351372528172?pt=LH_DefaultDomain_0&hash=item51cf6f4a2c
Total about $100. not bad compared to the $350 for AE. Plus I'll re-gift the tablet to my son come Christmas... becuase I'm a cheapskate
Swapping HPOPs between the two trucks... date on the door sticker of my truck says 01/99 My dads is a 2002. would there be any issues with 15* or 17* swash plate (correct term?) Also what are the odds I screw up and have 2 non functional 7.3s?
Amazon.com: BAFX Products - Bluetooth OBD2 scan tool - For check engine light & diagnostics - Android ONLY: Automotive
fram, personally...i'd leave your father's rig alone. Im thinking the difference in hpop's would also be a difference in pcm communications. Leave the dads rig alone until you get your goodies and see whats going on. BTW, with the amount of posts, cant recall if you or someone mentioned it, but, hows the oil level?
I'm using a Cheepie 8" HiSense tablet and the Bluetooth Bafx OBD dongle and it works good. Once you get all your new goodies in place, Buy Torque Pro and load it onto your Tab. Do yourself a favor and don't put anything else on it until you get comfortable with the software.... Not a steep learning curve, just not a whole lot of instruction on how to fire it up and do the setup/GPS/bluetooth Etc. Plenty of help here to get u there.......
Been doing more reading and research.... Could a bad o ring on an injector or multiple injectors cause my high oil pressure to drop? If a ring(s) were pissing oil into the valve covers, would it make sense that once the engine is warm (and the oil thinner) it would hemorrhage larger volumes of oil? That would further lower the IPC pressures and explain why it gets worse when warm? Help me out, the HPO system operates 500-3000psi? But what kind of volume? If it's a relatively small volume, then a not so large leak would be effect the pressure greatly? I think my reasoning is sound.... maybe.... Regardless, I'm thinking about pulling the valve covers tomorrow and cranking the truck to see if I got any volcanos spewing oil everywhere. Thoughts? Opinions?
Got my new toys. Android with torque and Bluetooth obdII unit. Ran it a little today. Seems that the hoop pressures are low and get lower while ipr% climbs until it's at 65% with any significant peddle. Tried to log it but screwed up and deleted it. Guess that's what I get trying to learn to operate an android phone and torque app on the same day. It seems pretty user friendly thiugh. Any advice on what PIDS I need to monitor?
There's a ton of PIDs here though
https://www.ford-trucks.com/forums/1...rque+pro+setup
#28
#29
Framblin, take it one step at a time,get familiar with your buttons and TP windows and settings. Your Hpop will only be at 700-800+ at idle, it doesn't start climbing until you start driving down the road. Read up on all the Torque pro threads and play with them for a while. Set your gauges up 1-2 at a time. using the Pre loaded PID's first, until you get comfortable with what your seeing....Then go hog wild.
#30
