Help, having trouble with fuel
I have a 81 150 with a 302 I'm not getting any fuel to my carb. Recently replaced my carb, it ran fine till the other day. I cranked my truck up to let it warm up, cranked just fine idled for a minute then it slowly died. Thought I ran it dry so I pour some gas in the front tank (it was running on rear), and was pouring dome into the carb trying to get it cranked (ran along as there was gas in the carb). Pull the fuel line at carb, to check mech pump, didn't pump any fuel. Replaced that still didn't work so i pulled my lines at the selector valve on the frame rail, had no fuel on either side or line. What could this be really need help as its ny daily driver
If you have no fuel at the valve anywhere, then you most likely have some sort of tank problem. If you are not sure, pick a tank you know has fuel in it, and hook it up straight to the line going to the front, bypassing the valve. See if the fuel pump will suck any fuel up front like that.
1975F2504X4
06-14-2015 07:25 AM
evanch123
08-31-2010 09:12 PM
VintageBlueOval
10-14-2009 06:49 AM
wcsd106
02-09-2008 01:13 PM
